Results 1 to 10 of 15
Thread: Front coil spring Mod'
    Regular Member old cruiser's Avatar
    slough
    Default Front coil spring Mod'
    I think this car of mine is falling apart LOL; seriously though, I get this sort of crunching noise when turning at very low speeds e.g when turning out of my driveway, thinking more about it, it sounds similar to when you drive over a piece of glass and you get that crunching noise, I did hear that there was an issue with the front coil springs moving in the lower seating on the strut and VX introduced a Mod' which was to fit plastic sleeves to the lower turn of the spring, however just been out to look at mine and they have already been fitted, so I'm suspecting it's the plastic sleeves making the noise? Has anyone else that has had this Mod' done , still experiencing the same problem?
    Cheers Pete
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    If you can try spraying some copper grease into the pan the spring sits into, it will help the spring move
    Tyneside
    Might also be the top strut bearings, mine went when I lowered the car and it was like a banging noise they made when turning the wheels.
    Regular Member markd3925's Avatar
    Eindhoven
    Vehicle : Vectra GTS
    dont sound like a spring sort of noise, what about rad mounts they modifyed them?
    slough
    Quote Originally Posted by markd3925 View Post
    What's the scoop with the Rad' mounts then?
    Cheers Pete
    slough
    Just read a field remedy regarding these plastic sleeves and the complaint is apparently ' Temporary cracking noise from front section' and the cause is described as 'Misfit between spring and lower spring seat' and hence fitment of the plastic sleeves.
    Cheers Pete
    Tyneside
    Quote Originally Posted by old cruiser View Post
    Cheers Pete
    They can make a noise when pulling away ro going over bumps, but never noticed it when turning. I just give them a squirt with WD40 and put some oil in them and sorted
    Eindhoven
    Quote Originally Posted by mark1319 View Post
    yes can normally get the noise by putting it in gear with the handbrake on and lifting the cluch abit
    just thought of that cos your would be pulling away at the same time as turning off your drive i guess
    slough
    Could give the mounts an oiling, however car is going into Vx on Tuesday for suspected oil pump noise (whirring sound when cold, disappears when engine's warm) so I'll ask them to check for this other noise and mention rad' mounts etc.
    Cheers Pete
    Tyneside
    There is new rad mounts available that are just rubber, the old ones have a spring holing them in. Easy enough to see if you have a look.
  1. Front offside coil spring
    By Tank988 in forum Vectra C / Signum Troubleshooting
    Last Post: 24th December 2011, 20:54
  2. Front coil spring advise
    By Graham in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2009, 00:35
  3. Broken front coil spring
    By Toyotacelicagt4 in forum Suspension, Wheels & Brakes
    Last Post: 18th August 2009, 18:18
  4. Front coil spring Mod'
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2008, 20:55
is vectra ccoil spring moving
vectra c spring mod
