Results 1 to 10 of 23
Thread: Problem is back again!!!!!
    Regular Member Andy17899's Avatar
    Jun 2007
    West Midlands
    Vehicle : Vauxhall Vectra SRI XPII
    Mileage : 68K
    Default Problem is back again!!!!!
    OMG! Its back, same fault, driving down the road, or accelerating at 50mph above, and limp home comes on with the car with a spanner through.
    Yet they are STILL saying they cant find a fault!!! they have replaced the boost sensor, so what on earth can it be?
    Arnold Flaming Clark clearly arent going to fix it, so is there anything i can do to fix it?
    WHen plugged in it is showing no fault, but clearly there is?!?!
    Larkhall
    I had the same problem with mine mate. Put the foot down over 50 and the light would come on. Had it checked by vauxhall's computer and they found no fault.
    In the end i got so p*ssed off with it i sold it lol
    Larkhall
    Oops - internet is playing up....... lol
    Jun 2007
    West Midlands
    Mileage : 68K
    Im thinking about doing that... but arnold clark have an oblihation to repair or replace, and they clearly aint gonna repair it, having said that, they still dont wanna replace it
    Larkhall
    I take it you're still no further forward? Can't you get in touch with their Head Office?
    Jun 2007
    West Midlands
    Mileage : 68K
    Yeah, they just say we will go with hat the garage says. Its crazy
    They are saying the branch i bougt it from (dundee) has 3 opportunities to fix it, although they have looked at it twice, an independant vauxhall dealer, preston arnold clark twice, and the AA twice. And still no fault found, although clearly the fault is there!
    Regular Member markd3925's Avatar
    Eindhoven
    Vehicle : Vectra GTS
    tell them you need a loan car and to keep your car till its sorted maybe get the service manager to use it and experience it for himself. that used to happen where i use to work, and it worked
    do you no if its not showing any dtc's or they just cant fix it
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Andy have you had the car tech 2 ed .If yes what fault codes were recorded.
    A few thing that you can check yourself
    1 vacuum hoses , check for splits in plasticpipes and rubber connectors also check the actuattors are still working (should be able to feel a suction over inlet pipes)
    2 Remove EGR valve give it a good clean with carburrettor spray make sure piston is free to move
    3 Clean out manifold housing with Carb spray making sure butterfly housing is free to move
    I did all of the above and it made a world of difference
    Winteringham
    I had exactley the same problem on mine once they had replaced the EGR, Swirl and Manifold and new turbo fitted, it turned out to be a hose going to the turbo that had a very small crack in it, only found it when they said they were going to replace the turbo again and I asked if they had changed the pipes when they changed the turbo, they had not once replace all ok and has been ever since.
    Jun 2007
    West Midlands
    Mileage : 68K
    i have no idea how to check all that mate? any how2's?
    also it has been plugged in but is showing no faults
  1. Replies: 0
    Last Post: 5th July 2012, 23:27
  2. EGR and Boost SENSOR cleaned but problem is back again already?!
    By VXR CDTi in forum Engine & Drivetrain
    Last Post: 7th September 2010, 17:13
  3. Help, the back ligth and back door not working after using hanger
    By joacom in forum Vectra C / Signum Troubleshooting
    Last Post: 19th April 2009, 15:24
  4. Milau Trip - back seat report...WE'RE BACK!!!!
    By Duncan in forum General Chat
    Last Post: 30th September 2007, 12:53
  5. Replies: 15
    Last Post: 27th July 2007, 08:58
