Thread: Lower steering shroud
    Nov 2007
    Wales
    Default Lower steering shroud
    Hello all.
    Any tips on removing the lower steering shroud just behind the steering wheel, before I break any hidden clips.
    Victor
    Nov 2007
    Wales
    Someone must have had this cover off. I've taken out the two screws behind the steering wheel and the one underneath just behind the colum adjuster but it still won't budge.
    Sunny Dartmoor
    Never done it,why would you want to remove it.....
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I did it when i changed my dash i take it you have removed the top shroud ?
    you have the 2 screws either side of steering wheel and the 2 screws on the switch assembly on top (once top shroud is removed you will see these)
    Then you remove the circular trim panel from around the ignition switch
    then undo the two screws on the steering height adjuster handle then when you remove that handle you will find another screw there
    that should be it hth
    Nov 2007
    Wales
    Unhappy
    Thanks Bigmac thats great, but how do you remove the top shroud?
    BTW changing the bottom shroud due to it being incompatable with tree air freshner (strips of grey coating). Does not look good on a 6 month old car.
    Victor
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    I had the same problem, stain on the lower steering shroud
    The dealers changed mine for me £37 all in
    It was classed as trim so wouldn't change it under warranty
  1. steering column shroud
    By chaddopete in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2010, 17:13
  2. Replies: 3
    Last Post: 25th March 2009, 14:02
  3. Cold draft form steering lower panel
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2009, 19:41
vectra c steering column shroud removal
