Results 1 to 10 of 16
Thread: Brake Judder on new discs
    Regular Member jamesr's Avatar
    Lancashire
    Default Brake Judder on new discs
    I have just fitted my new drilled discs and they are CRAP at the moment....
    There is no bite to them and from high speed +60mph they just judder when you touch the pedal.
    Do they take a bit to bed in?
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    you need to take it easy for about 200-300 miles so try and avoid any heavy braking or you WILL warp the discs
    Lancashire
    Fitted on Wednesday and already done 400 miles - but no improvement
    Jul 2006
    AFAIK it's more to do with the pads than the discs - what pads are you using?
    Lancashire
    I didn't fit new ones cos only fitted 2 months ago, they are police spec pads.
    Ashington, Northumberland
    When you say 'judder' can you feel the pedal pulsing under your foot? ie moving rapidly up and down as you brake? If that is the case then you may have a warped disc (unlikely being that they're new, but not impossible), or more than likely, you have excessive runout on one or both discs. This would require you to remove the discs again and clean up the mating surfaces. As for the brakes being crap, if you have excessive runout, the pads will be being knocked away from the disc, by the disc if you follow me. Depending on the pads being used depends on the length of time they need to bed in well with the discs (some friction materials are harder than others).
    edinburgh
    Quote Originally Posted by jamesr View Post
    Excuse my bumbness, what is police spec?
    Admin plasma's Avatar
    On the Forum
    247 Post(s)
    Engine : 150
    Mileage : 74000
    a nice soft pad with a lot more 'feel' to it under braking than standard aftermarket pads. Normally used on police vehicles. Think they are mintex pads?
    Thornton Dale
    Vehicle : Transit Custom
    Trim : Limited
    Engine : 125PS
    Your old pads, 2 months old, had worn to surface shape of your old discs.
    So your now, nice flat new discs have uneven pads on them.
    Really bad practice, new discs and new pads, always at the same time.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by SYMON View Post
  1. Brake discs
    By Handyandy-UK in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2011, 23:55
  2. Brake discs.
    By mally in forum Suspension, Wheels & Brakes
    Last Post: 29th January 2011, 10:45
  3. Hot brake discs!
    By MickAP in forum Suspension, Wheels & Brakes
    Last Post: 31st October 2010, 23:44
  4. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  5. sri brake discs
    By studmuffin in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2009, 11:39
