Thread: fuel pressure sensor
    southampton
    Default fuel pressure sensor
    Can anyone tell me where i would find the fuel pressure sensor on a 2.2 dti sri? I know its suppose to be on the fuel rail but its location is a mystery to me!
    thanks
    Regular Member benny's Avatar
    Feb 2006
    dudley
    there isnt a fuel presh sensor as you would think there is it is based inside the pump and isnt a serviceable item ...there also isnt a fuel rail fitted to the 2.2 diesel engine ....what problem do you have? .....
    southampton
    hi
    well its not a problem as such. I brought a diesal tuning box form diesal tuning uk who assured me it would fit but wel i was having trouble finding the fuel prssure sensor which it says i need to plug it into.
    thanks
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    Sounds like the box is meant for a 120/150ps CDTi and not a 2.2DTi. Boxes for the DTi's sometimes have to be soldered onto the pump wires if its a 2 plug pump, one plug pumps can be plugged in... Double check which tuning box you have matey and post up here.
    southampton
    when you say one plug what do you mean exactly. Mine has two three pin plugs that i am ment to unplug my standard sensor plug the box in and then plug the old sensor back into the other plug on the box i tink.
  1. Fuel Rail Pressure Sensor - another thread
    By Stevo2 in forum Engine & Drivetrain
    Last Post: 30th June 2010, 20:52
  2. Fuel pressure sensor
    By Eminox in forum Engine & Drivetrain
    Last Post: 7th June 2010, 20:35
  3. Fuel Rail Pressure sensor
    By RobW in forum Engine & Drivetrain
    Last Post: 3rd December 2009, 16:55
  4. P1191 - fuel rail pressure sensor circuit low input
    By L11Marc in forum Engine & Drivetrain
    Last Post: 17th March 2009, 17:12
  5. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
vauxhall vectra sri fuel pressure sensor location
vectra c fuel pressure sensor pin out
