Thread: 3 button key problems (vx tech needed)
    Regular Member martinbruce's Avatar
    Wales
    Default 3 button key problems (vx tech needed)
    Why me??
    Right,
    Bought a horseshoe with transponder attached and a blank blade.
    Bought a spare key fob and changed them over. Got the key cut this morning and off I went to the stealers for a session on Tech 2 to get the new key programmed.
    After an hour I enquired as to what was happening??
    Was told that they couldn't program the key because it had an "in-active transponder"?? WTF is that?
    Have ended up paying £51.03 for a flip key and another session on Tech 2 @ £23.50 to get it sorted out.
    If anyone can help, I can get this "rouge" key sorted and put away as a spare, spare.
    Cheers guys/girls
    Martin
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    If its a 2nd hand key you bought the transponder would have been coded to another vehicle. You cannot reprogram transponders from one car to another (the little black chip inside the key which tells the immobilser to turn off).
    The keyfob itself can be reprogrammed without a problem. You need to purchase a blank transponder NOT been programmed.
    Wales
    Seems there are 3 suppliers of keyfobs for the Vectra/Signum.
    This is the answer I got....
    QUOTE
    sorry about this do you have a fob for it already if so what is the code of the back of the key there are 3 suppliers vauxhall used to manufacture these fobs they all look alike but a few hanfulls are made by megamos if its one of these it will have it writen on the chip board where you battery is inside your fob
    WILL WAIT AND SEE......
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    Thats correct, there are a couple of different type of keys dependant on what car it is. Megamoss was used a lot on the Vec B, on my 3 button old style Vec C key fob there isnt any visible name . On the back of it i have 3 sets of numbers CTX8435, 507837, 12230083. Hope these may be of some use to you
    Wales
    Quote Originally Posted by plasma View Post
    Cheers Plasma,
    Your comments are very helpful thank-you.
    On my fob I have
    CTX 8323, 484312 and 12230083 A
    On the fob I received i have
    CTX 8326, 484975 and 12230083 A
    Not really sure what all that means
    Do you know?
    Martin
  1. Tech 2 Help Needed Please
    By Bethan39 in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2010, 13:10
  2. tech 2 with tis needed
    By davidjameswest in forum South Wales (RO - Vacant)
    Last Post: 2nd December 2009, 11:15
  3. tech 2 needed
    By mhvcbv in forum Electrical & ICE (including SatNav)
    Last Post: 9th March 2009, 14:23
  4. s button fob casing needed
    By appy in forum General Chat
    Last Post: 23rd November 2007, 19:45
  5. Tech 2 problems
    By The converted in forum Vectra C / Signum Car Chat
    Last Post: 15th August 2007, 20:12
12230083 A
opel vectra c 12230083a
