Results 1 to 10 of 13
Thread: Auto-dimming mirror circuit
    Regular Member old cruiser's Avatar
    slough
    Default Auto-dimming mirror circuit
    Been trying to get the auto- dimming mirror working, but come to a halt; took connector off both the mirror and the other end that goes into fuse box area in the boot, checked continuity between both ends and proved that the ribbon cable is good, however there is no Voltage on any of the pins (only 3 pins on the ribbon)) and also checked each one on the fuse box connector itself (with ignition ON) and no volts there, question is what volts should I be seeing as I expected at least one of the 3 pins to measure 12V and is there a fuse for this circuit as none mentioned in the manual and don't want to take all fuses out to measure as knowing my luck something will have to be Tech2'd afterwards!! any ideas guys?
    Cheers Pete
    Sunny Dartmoor
    I would check fuses first,as there is one for the mirror,should'nt have any tech2 issues pulling a fuse m8
    slough
    Couldn't find any mention of a fuse in the handbook or haynes manual, but saw a post from some other guy that had a similar problem and he found fuse No. 27 (in the boot fuse panel)missing and he replaced that and all was well, mine was also missing so fitted one in there, but still doesn't work, also noticed in the manual that this fuse is for: Seat occupancy recognition, tyre pressure monitoring, rain sensor and air conditioning, which is strange as air-con and rain sensor systems worked on mine although this fuse 27 was missing!! just don't understand what's going on.
    Cheers Pete
    Administrator plasma's Avatar
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    FR27 controls Right Hand Airbag multistage, Right Hand Airbag single stage, TPMS, Sunscreen through XR1 (Middle plug bottom row),
    through plug XR8 (top row 3rd along lower ribbon cable) Pin 12 (ribbon cable) Pin 1 (at the mirror) is the 12volt run/crank feed, Pin 11 (ribbon cable) is the O volts (Pin 2 at the mirror), Pin 10 (ribbon cable) rain sense signal (pin 3 at the mirror)
    Sunny Dartmoor
    In english would help plasma.....
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    Quote Originally Posted by plasma View Post
    he`s showing off with his new tech2 ainta dean
    but really he aint got a clue pmsl
    oh hi dean howz it going,when do u want ya stuff doing on ya car ???
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    lol look at you u little girl Tech2 aint got booger all to do with this one mate, its all down to good old fault finding with a multimeter, I'll give you a lesson in using one when i go up there Still waiting on me bluddy TPMS repair plug, other than that its all good to go.
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    Quote Originally Posted by glenboy View Post
    The OP seems like he knows what hes looking at so just replying at the same level of understanding he is showing.
    slough
    Thanks for that mate, just gone out and checked orange/yellow light and dimming of mirror now that it's dark and would you believe it the whole damn thing's working now and in the process managed to sort out a wiring diagram and it shows FR27 wired through to XR8 pin 12 as you mention and then to EIS (Electrochromatic Mirror) so it would appear that FR27 being missing was the culprit and can only assume it was never fitted at the factory for some reason!
    Cheers Pete
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    no worries, glad its all working for ya
  1. Auto dimming mirror
    By nikroc in forum Electrical & ICE (including SatNav)
    Last Post: 18th November 2012, 13:46
  2. Auto wipers.. and auto dimming mirror ?
    Last Post: 28th January 2009, 01:24
  3. Auto dimming mirror
    By abbeytec in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2008, 09:20
  4. Auto Dimming Mirror/Auto Wipers
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 21:42
