Results 1 to 3 of 3
Thread: Amazingly Simple Home Remedies-#3 is awesome!
    Birmingham
    Talking Amazingly Simple Home Remedies-#3 is awesome!
    *AMAZINGLY SIMPLE HOME REMEDIES:*
    !!!WARNING-DONT TRY THESE AT HOME!!!
    1. If you are choking on an ice cube, don't panic. Simply pour a cup of boiling water down your throat and presto! The blockage will be almost instantly removed.
    2. Clumsy? Avoid cutting yourself while slicing vegetables by getting someone else to hold them while you chop away.
    3. Avoid arguments with the Mrs. about lifting the toilet seat by simply using the sink.
    4. For high blood pressure sufferers: simply cut yourself and bleed for a few minutes, thus reducing the pressure in your veins. Remember to use a timer.
    5. A mouse trap, placed on top of your alarm clock, will prevent you from rolling over and going back to sleep after you hit the snooze button.
    6. If you have a bad cough, take a large dose of laxatives, then you will be afraid to cough.
    7. Have a bad toothache? Smash your thumb with a hammer and you will forget all about the toothache.
    8. Sometimes, we just need to remember what the rules of life really are.
    You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
    9. Remember: Everyone seems normal until you get to know them.
    10. Never pass up an opportunity to go to the bathroom.
    Bye bye Vec B
    - Hello Siggy!
    Sunny Dartmoor
    My favourite.....
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    very good give me a few laughs haha
  1. Newbie...came looking for remedies
    By Exxentrix in forum Introduce yourself.
    Last Post: 28th February 2010, 18:58
  2. Hayfever Remedies???
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 24th June 2008, 21:03
  3. Amazingly simple home remedies
    By Johnsdutton in forum Comedy & Humour
    Last Post: 21st May 2008, 20:10
  4. Field remedies
    By storey_3000 in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2006, 17:50
  5. BTCC awesome awesome
    By ian_c in forum 2006
    Last Post: 16th May 2006, 07:49
