Results 1 to 3 of 3
Thread: Help! Gearbox troubles
    Regular Member n30jjb's Avatar
    Barnsley
    Default Help! Gearbox troubles
    I have recently been having troubles and have taken my 04 Signum 2.2dti Auto to my local vauxhall dealer. It's A long story so please bear with me.
    1. About 3 weeks ago I got the "safe mode" warning light and the engine mamagement light on the dash. Booked in at VX nextday.
    2. Got told by VX vacuum pump for exhaust knackered £140.00 to fix it, so they did.
    3. Two days later lights back on the dash, booked back in at VX and they said they couldn't find anything wrong and reset the faults/computer.
    4. On monday of this week the lights back on the dash so booked it in again at VX didn't drive it on tueday apart from to VX which is about half a mile away from my house. They called wednesday and said that the oil coolant had leaked and had mixed with the gaer box fliud so they needed to fix the leak and swap the fluids. I agreed for them to do the work. Today I had a call from them to say the had done the work but the lights were still on the dash and this means that I need a new Gearbox at the measly cost of £3100.00.
    I have not had any problems with the gearbox (which is automatic) changing gears or grinding etc other than when the car is in "safe mode" and I can only select gears 2 and 5. This is normal according to VX. Other than that the gearbox runs nice and smoothly. The car has only done 38,000 miles from new and I am suprised if the gearbox is damaged.
    If the gearbox is damaged could this be to excessive driving and could it have been prevented if the problem had been spotted earlier?
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    the oil cooler thingy leaks and mixes with the gearbox oil and thats what causes the gearbox to go bad i believe. there are quite a few threads on this if you'd like to do a search for them, Auto boxes arent really my area of knowledge though
    Yorkshire
    Well I can save you some money, our local dealer sends all automatic's to the Transmission specialists at Hoyle Mill who charge less.
    Mine wouldn't move at all but I found if I removed and cleaned up the 2 sensors of the metal fragments stuck to them it would drive again. It may be worth trying and if it resets trade it in quick!
    I'm just in the middle of replacing mine and its not an easy job.
  1. Gearbox troubles?
    By barney9304 in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2011, 13:53
  2. sat nav troubles
    By woodze in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2010, 23:30
  3. HiD Troubles...
    By Dan_BlackSRi in forum Electrical & ICE (including SatNav)
    Last Post: 14th October 2008, 23:19
  4. car troubles
    By Steven in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2006, 10:02
