Results 1 to 10 of 15
Thread: BrAkE REWIND TooL ????
    Mossley
    Default BrAkE REWIND TooL ????
    Hello all, can anybody give advice on the best place to get a brake rewind tool and how much should i be paying for one ??? Many thanx in advance
    Regular Member willoftoon's Avatar
    FOREST HALL NEWCASTLE ,,,,,OR DECKHAM ,, ON SUNDAYS .. DINNER TIME MAMMY,S
    ebay m8 cheap
    Mossley
    Also is it a good idea to bleed when changing brake pads
    Mossley
    thanx will check ebay out
    Regular Member caledonia's Avatar
    Scotland
    Hi and welcome. I see one the other night in ebay.
    http://cgi.ebay.co.uk/VAUXHALL-VECTR...d=p3286.c0.m14
    here you go
    cambs
    Quote Originally Posted by StarDingle View Post
    no need to bleed the brakes m8
    rewind tools is for only the rear pads
    front dont need the rewind tool
    Mossley
    Thanx fella just had a look, theres 2 on there i might just go for the other 1 as it does a lot more makes / models, little bit more expens though hey it'll be better than using long nose pliers and a little easier GREAT & TA
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    I got a small square socket type thing of Ebay for just a few pounds. It has a different pin setup on each side and the ratchet just pushes on and it works a treat as used on my wifes ex Focus
    11 Post(s)
    Quote Originally Posted by mhvcbv View Post
    There is if you do it the correct way and slacken off the bleed nipple before pushing/winding the pistons back into the brake caliper. By forcing brake fluid back into the master cylinder there is a risk of flipping the rubber seals. Also it's not good practice to force dirty brake fluid back through the ABS pump either.
    cambs
    hi
    i was told that thier was no need to bleed.
    but i can see what you are saying and makes perfect sense.
    will do it that way next. cheers for that m8
  1. Brake Rewind Tool
    By LeeU in forum Suspension, Wheels & Brakes
    Last Post: 10th September 2011, 11:21
  2. Brake rewind tool
    By scotty84 in forum West Midlands
    Last Post: 26th March 2011, 22:01
  3. Brake rewind tool.
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2010, 08:32
  4. brake rewind tool
    By Darren68 in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2009, 16:24
