Results 1 to 10 of 11
Thread: 12s vauxhall wiring
    wirral
    Default 12s vauxhall wiring
    hi
    has anybody on here fitted the genuine vauxhall 12s socket what im after trying to find out is does it plug into rear of car like the 12n socket ??
    thanks all
    Oct 2007
    Reading
    Vehicle : SAAB 93 Estate, Vectra C Estate
    Trim : LINEAR SE, Elite
    Engine : Z19DTH, Z22YH
    Year : 08,08
    Updated:
    Similar, uses two of the free connections on the 12N wiring plug shown on the right, the red wire is pre fitted with a connector which pushes in to the second hole up right hand lower corner, the white / black wire is supplied with two connectors one for the Vectra and one for the Meriva etc so you need to crimp the appropriate one on and then push in to the second hole down left hand top corner. You also plug a twin fuse adapter (supplied) into a ignition switched fuse (left), I used F28. This adapter requires a 20A mini blade fuse not supplied (mine has a 10A at the moment, hence the red fuse) and then you also require a 20A mini blade fuse to fit in F13, again not supplied (blue fuse shown as mine is currently 15A).
    Note to self, must get the correct fuses.
    wirral
    http://cgi.ebay.co.uk/Vauxhall-125-T...d=p3286.c0.m14 seen this on ebay seems to be a different part no wot do u reckon does it look the same or should i just buy 93160573 for vectra ??
    thanks for your help
    Oct 2007
    Reading
    Year : 08,08
    Well, it a quarter of the price, defiantly different, but depends on your skills, 12S wiring is relatively simply on a Vectra compared to 12N. Down to you really.
    wirral
    skills arent to good with electrics still havent fitted the 12n yet only just got the car and bought towbar but not the electrics yet but want both 12 n and 12s so let u know when i get them if i get stuck
    thanks again
    Oct 2007
    Reading
    Year : 08,08
    Don't forget the 12N may need Tech 2'ing. Try with the caravan first though, you might save yourself £36 or so.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    what is the difference between 12n and 12s? as i dont know whats fitted on mine...
    Regular Member daneboy35's Avatar
    darvel,ayrshire
    12n is your normal lights ie side lights,indicators and brake,12s is for battery charging on a caravan etc and also reverse lights etc,hth
    Engine : 2.2 Direct
    that would mean its the one with "13 poles" in it.. (if yes then mine is 12n )
    Oct 2007
    Reading
    Year : 08,08
    No both 12N (black) and 12S (white or grey) are 7 pole.
    13 pole is a European version combining both in one plug but the fridge charging circuit is not always connected.
  1. Idiots guide to wiring in original Vauxhall Xenon headlights required please.
    By Duncan in forum Electrical & ICE (including SatNav)
    Last Post: 25th June 2010, 18:29
  2. GM Vauxhall wiring loom plugs
    By plasma in forum Vectra C / Signum Car Chat
    Last Post: 31st October 2008, 01:15
  3. vauxhall facia and wiring kit
    By DennisTheMenace in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2007, 17:13
  4. Vauxhall TIS 2005. Diagnostics, labour times,wiring diagrams etc etc
    By Robbieben in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2006, 18:02
vectra c 12s wiring
opel z22yh normal o2 value
