View Poll Results: Cruise control Actuation - brake pedal check required?
Voters
87. You may not vote on this poll
  • Pre-face lift - NO pedal check needed
    16 18.39%
  • Pre-face lift - pedal check IS needed
    31 35.63%
  • Face lift - NO pedal check needed
    5 5.75%
  • Face lift - pedal check IS needed
    35 40.23%
Results 1 to 10 of 29
Thread: Cruise control Actuation - is brake pedal check required?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Default Cruise control Actuation - is brake pedal check required?
    Just to understand the differences.
    Can people vote on if Cruise control will activate without pressing the brake pedal at all from first start?
    There is a logical reason for this brake pedal switching check, but not all Vecs need it - does yours?
    Tyneside
    Yep does in mine as I mentioned in the other thread, a bit of a PITA as when I'm coming from services etc I don't always use the brake so I then have to press the pedal to use the CC, being petty I know LOL.
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    This used to baffle me for the first six months, sometimes it seemed okay, but when it failed to I noticed that if I dabbed the brake pedal it would then come on.
    It does state in the book that the pedal must be pressed once after starting before the cruise will work. Many just dont read the manual....including me. Must be some safety reason for it.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    As mentioned in the other thread, both of my pre-facelifts need it pressed before engaging. However when it's me driving and not the missus it's already been pressed once before pulling away as I tend to put my foot on the brake whilst starting the car.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Quote Originally Posted by mark1319 View Post
    Maybe I'm being daft, but can't see why it would be a 'NO'. Maybe it's 'designed in' to ensure it cannot be activated inappropriately and can always be easily reactivated. Maybe it's overkill, saw something yesterday about a vehicle whose cruise control could develop a fault where if could not be immediately switched off once activated.
    Melbourne, Australia
    I would've thought all Vectras would require brake use before enabling cruise control. I guess it would only bother manual transmission drivers since BTSI will stop you shifting out of park on an automatic trans.
    You'd think that you'd ALWAYS use it at least once, even if only for a second, before you got into a situation where you'd actally need cruise control...
    Didn't even know it existed, but seems a sensible precaution so the computer knows the brake cut-out switch works...
    Yes, as I think it states it in the manual.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    As long as you don't do what some drivers do who will refuse to brake until the latest moment possible so as not to have to switch cruise control off. Apparently on some Belgian motorways the use of Cruise Control is banned (now how do you enforce that?) (unless it's a spoof report) as there were collisions blamed on the use Cruise Control and not switching it off to maintain a safe distance behind the car in front should anything untoward happen. I've heard of maximising fuel efficiency but sometimes drivers' obsession with fuel economy turns them into bad drivers, as fuel economy is more important than consideration for other road users, or driving safely.
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    Will vote once tested
  1. Help required to activate cruise control
    By Daywalker in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2013, 11:24
  2. cruise control brake switch
    By Al 22 dti in forum Electrical & ICE (including SatNav)
    Last Post: 16th June 2011, 18:57
  3. For Sale: Clutch Pedal Switch (cruise control)
    By Big Knox in forum Parts for sale
    Last Post: 30th April 2011, 09:15
