Results 1 to 10 of 14
Thread: Cruise Control problem, HELP pls
    Apr 2008
    west mids
    Default Cruise Control problem, HELP pls
    Hi there,
    My cruise control lately has a mind of its own
    It sometimes works ie light shows on dash and sometimes it just point blank refuses to engage
    Didnt work one day and then it did in the night and then next day didnt work again!
    Is there something i need to do?
    Regular Member s0501291's Avatar
    Warrington
    I had the same problem on mine,, Somthing that you can try is pulling the clutch pedal up with your foot when your driving. Their is a switch on the clutch pedal that dis-engauges the cruise control when you press the clutch. Somtimes the spring which is supposed to return the pedal to the fully up position when your foot is off the clutch can break or be strained. If you find that the cruise control works when you pull the clutch up fully then you probably need an new pedal spring, OR you could do some DIY on the switch by gluing in somthing that will take up the slack.
    Hope this helps
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    yup mine was the same till i got a spring for the rear of it..
    Regular Member gogs37's Avatar
    inverallochy
    im having the same problem but it always fixes itself when i restart the car
    Belfast
    Faulty stalk?
    Tyneside
    You have to press the brake as well, found this out when I came out of services and it wouldn't work because I hadn't pressed the brake.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Mine used to malfunction, was dirty contacts on the stalk. A bit of contact cleaner and a few good presses and it's been OK since.
    Not sure about the having to have actuated the brake pedal once before it will engage. I read it before on here and understand the reasons for it (to ensure brake actuation will disable CC and not get the engine powering against braking when you press the brake, as you may need to stop quickly, and don't want extra braking distance from the engine straining too)
    Belfast
    It clearly states in the manual that you need to depress the brake once before the CC works. I believe it's to ensure the brake switch is working, so you don't end up with the CC fighting the brakes in an emergency.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    My car definitely does NOT need the foot brake to have been operated before CC will engage.
    I tried it last night when i filled up with petrol, and this morning when I went to work.
    Belfast
    Then your car is faulty...
  1. different cruise control problem
    By greenmeanie in forum Engine & Drivetrain
    Last Post: 2nd December 2015, 19:42
  2. cruise control problem
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2012, 22:07
  3. Cruise Control Problem
    By gsi.vxr in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2010, 13:16
  4. cruise control problem
    By Lee.. in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2009, 21:37
  5. cruise control problem
    By Herman in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2008, 19:10
https:www.vectra-c.comforumshowthread.php60386-Cruise-Control-problem-HELP-pls
vectra c cruise control problem
