Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: rear quarter window
    Regular Member willoftoon's Avatar
    FOREST HALL NEWCASTLE ,,,,,OR DECKHAM ,, ON SUNDAYS .. DINNER TIME MAMMY,S
    Default rear quarter window
    is there a how 2 as i need to get them changed to me chrome he say s just 6 nuts take side panel off and thats it other say whole back of interior needs to come out ,, HELP pics if any 1 has done it needed or info what to remove and how
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    remove the the parcel shelf
    put the seat forward and remove the lower side panels
    remove the panels that surround the window (held in by torx 15/20 bolts)
    then undo the 6x9mm nuts
    hope this helps
    cambs
    what out for the rear left pillar m8
    its got wires/ribbon cables in it
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    As above really, took this from Oil burners' How To on rear light installation:
    working from the boot, pop the tab from the passenger side C-pillar trim, remove the two visible screws, unscrew the passenger seat belt from the top anchor and the lower boot trim. It helps to remove the side portion of the seat (the bit attached to the car) for access.
    You will see 3 torx screws (everything seems to be torx heads!), one hidden near the seatbelt top anchor. Remove all these. Pop out the lower plastic boot cover (behind the seats). Remove the boot light.
    Then carefully remove the boot trim from the passenger. It will have one plastic clip holding it in place.
    You should now have access to the entire rear fusebox and see the wiring harness running from there up to the roof, through the C-pillar trim.
    Have a look at the picture from when I had my headlining out, I also think they may be bonded in, I remember seeing a picture on here of Mark/GSI3.2 levering a rear quarter out.
    HTH
    cheers will have a go at weekend with laptop in car with me
    had a look at this today didnt do it what i need to know is the rear panel that runs down rear windowdoes it have airbag in it as it has a thing that looks like a airbag hole ..
    no air bag in that part fella just give it a good pull but as said, mind the ribbon cable but should be ok as its mainly stuck to the roof linning
    cambs
    beat me to it glynn
    sound will have a go tomorrow just has a grey plug thing that looks like some sort of bag thing ..cheers lads
    cambs
    hi
    if you are on about the cover thats above the seatbelt.
    its just a clip that hold the trim on.
    just pull it out m8
  1. Rear quarter
    By leedslads in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 19:36
  2. Fittin chrome window sills/rear quarter glass and a car smash!!!
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2010, 01:17
  3. Replies: 8
    Last Post: 9th September 2009, 10:33
  4. Help with rear quarter window
    By Itsallrover in forum Bodywork & Interior
    Last Post: 12th May 2008, 21:53
  5. Rear Quarter Window Problem
    By bigcraig in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2007, 17:28
vectra c rear quarter window removal
