I reckon mine is on it's way out, as there is a 'throaty' noise when 'blipping' the engine when stationary.
If the rear silencer is blowing, what is the part I need and how much are they?
2004, 1.8 LS
TIA
2004, 1.8 LS
TIA
If the rear silencer is blowing, you need a new right front wheel bearing, 4 new discs and pads, four tyres and your brake fluid changed. Or is that just Kwik-Fit?
I try to avoid KF, cos they will try to get to buy all the above, and possibly more too.
I've found Bosal exhausts to be pretty good, and I think they're factory fit on some Vauxhalls (my Corsa C had a Bosal system on it at new). Most motorfactors should be able to supply them, and a mechanic can fit it in 10 mins if you're not up to doing it yourself.
I'll be doing it myself, probably.
I have had a look, and now I'm not sure it is actually the silencer. I will have to get it over the pit for a proper inspection.
