Results 1 to 3 of 3
Thread: Whats going on??
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Default Whats going on??
    I have a problem with my stereo. basically when you turn the ignition off and remove the keys the stereo goes blank but all the lights are on and i can hear noise from the speakers and the trip computer stays on. i have disconnected the stereo and it seems to of sorted the problem but now i have no music. I have an inphase stereo. anybody know whats going on here?
    SUFFOLK
    Had this on my 04 vectra. Mine did roughly the same. Appeared to be an issue with the radio and other bits of the CANbus getting out of step.
    Essentially main CIM module (basically the master controlling module on the car) sends an off command to the radio and display which one of them ignores. The CIM then refuses to talk to the radio properly again.
    Best thing you can try is disconnect the battery for 10 minutes and allow the memory in the modules etc to fail. Then reconnect the battery and everything should spring back into life. This may only temporary fix it as dealer replaced the radio in mine a couple of weeks later under warranty.
    Jul 2006
    Northampton
    Trim : Sri
    ill give that a go then, cheers mate
  1. Whats in the box
    By bigmac in forum Insignia car chat
    Last Post: 21st September 2011, 18:08
  2. Whats in the box?
    By Ginge7289 in forum Styling
    Last Post: 19th September 2011, 22:00
  3. Another whats in the box..
    By blue estate in forum The 'Off Topic' room
    Last Post: 10th May 2009, 21:54
  4. whats best to use?
    By Mads in forum Detailing and Car Care Discussion
    Last Post: 26th July 2008, 01:04
  5. Whats The Name
    By lilangel in forum General Chat
    Last Post: 8th April 2008, 20:21
