Results 1 to 10 of 13
Thread: Signum - Water In Spare Wheel Well
    guildford
    confused Signum - Water In Spare Wheel Well
    Hi
    Does anyone have this problem.. My 54 Signum gathers water to the extent that it fills the spare wheel well located in the boot. I know I have a slight crack in one of the rear light clusters but i cant beleieve that amount of water seeps through that gap to end up in the spare wheel. Plus it only seems to happen if the car has been washed either with a normal hosepipe or jet wash, makes no difference as the same amount of water ends up in the wheel well.
    I think it can only be one of two things..either the rear light cluster has a be fiddle dwith previously and the seal is crap or condensation..I only say the latter as when i lift up the floor compartment to access the spare wheel, the actual wheel itself and the surrounding floorplan is covered in condensation droplets.. can anyone help?
    Surrey
    Isn't it the pressure difference that draws water through the rear lights? Change the rear light is my advice especially if it is cracked.
    PS Near Leatherhead here.
    it will more than likely be the poor seal given by an ageing foam gasket..... they are cheap from VX..
    Surrey
    Perhaps clear silcon sealant new one in then.
    not really, as it needs to be removeable to change any blown bulbs.....unlike vectra to access the bulb holder you have you remove the entire lamp unit, much the same as corsa B (2000 on ) ...
    Surrey
    Oh god what a pain, Ford Focus is like that too.
    Regular Member shan's Avatar
    Andy L had his rear seal's change under warranty on his Signum.
    Same thing wheel well and load floor sopping wet.
    Belfast
    Had that problem on a saloon Chevette. Drilled a hole in the wheel well, lets the water out. Problem solved.
    Surrey
    Quote Originally Posted by _ZS_ View Post
    I did similar in a BMW boot side pocket but didn't want to admit to doing that.
    Regular Member corman's Avatar
    Mar 2007
    hexham
    well if we're all confessing..... my vw sharan has a nice 8mm drain hole in the passenger floor
    but i did put new underseal on the exposed edges
  1. Water in spare wheel well!
    By andyrad29 in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2018, 21:22
  2. Water in spare wheel well after aerial repair
    By coooky in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 21:54
  3. water in spare wheel well
    By surfage in forum Vectra C / Signum Troubleshooting
    Last Post: 15th October 2012, 12:13
  4. Water in trunk and spare wheel getting rusty
    By matt89 in forum Bodywork & Interior
    Last Post: 26th August 2012, 09:55
  5. Water in spare wheel well
    By Sam in forum Bodywork & Interior
    Last Post: 25th July 2007, 17:09
corsa b repair wheel well
