Results 1 to 10 of 14
Thread: any 1 else got this wierd sound when ar warmed up!!!!
    Regular Member vectramad's Avatar
    Jan 2008
    portsmouth
    rolleyes any 1 else got this wierd sound when ar warmed up!!!!
    as above cant really describe it ,but when my 1.8 sri vvt warms up and i pull away or say im just driving it a bit harder on the gas pedal theres sort of like a virbrating sound coming from the front end somewere!.
    any no what it could be or does any 1 get the same problem!!!!!
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    I sometimes get this when my air-con is switched on. There's a bit of a funny rumble/rattle for about 2 seconds then it goes.
    Is your air-con switched on?
    Snowman, you got your ears on?
    Belfast
    Probably the exhaust resonating, mine buzzes a bit around 3500rpm.
    Regular Member amiddleton's Avatar
    May 2008
    Hull
    Does it feel more like a rumbley knocking.
    Andy
    Jan 2008
    portsmouth
    Quote Originally Posted by Taffyopel View Post
    no m8 air con is off!!!
    Jan 2008
    portsmouth
    dosent feel like knocking, nor the exhaust.
    it sounds more like a vibrating sound
    Regular Member markd3925's Avatar
    Eindhoven
    Vehicle : Vectra GTS
    clutch slip?
    Jan 2008
    portsmouth
    Quote Originally Posted by markd3925 View Post
    clutch slip?
    dont think so!
    just pressing the gas pedal it makes the soubd.......
    Regular Member old cruiser's Avatar
    slough
    Check the exhaust heat shields
    Cheers Pete
    Regular Member jared.ryder's Avatar
    Jun 2007
    NORFOLK
    i took mine to vx for a similar prob and it turned out to be the radiator mounts. replaced them and cured the prob.
    Just a thought
  1. fault p0100* but only when engine warmed up
    By mack in forum Engine & Drivetrain
    Last Post: 3rd July 2013, 08:38
  2. Replies: 18
    Last Post: 15th August 2012, 20:36
  3. idle problem when warmed up (3.2 v6)
    By lee866 in forum Engine & Drivetrain
    Last Post: 14th March 2010, 10:06
  4. hids wierd
    By andy_hare in forum Electrical & ICE (including SatNav)
    Last Post: 5th February 2010, 21:03
  5. Its a wierd one but need help!
    By Kyser143 in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2008, 21:29
