Results 1 to 10 of 24
Thread: 314 Set Up Lacks Bite
    Nov 2007
    Lincs
    Default 314 Set Up Lacks Bite
    Hi everyone
    I took the opportiunity to do the 314 upgrade when Saab were advertising their set up on the site. Ive always noticed that the pedal seems to travel quite a bit - lacks bite. This has been more noticeable recently when driving my VW Passatt 2.0tdi company car whose brakes nearly put you through the windscreen. Whats your thoughts on this upgrade guys? Do you think I need another bleed or could my pads be the issue - only done 2k since fitting.
    Surrey
    Mine travels a bit further but certainly sops a lot better.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    There's a few posts like this. I wonder if the bore in the 314's is larger than the 285's, this would give a longer pedal.
    Nov 2007
    Lincs
    I initially thought about changing the pads to the Police Spec if they do them for the 314 set up and changing the fluid to a different spec, but i thought i would ask here just to see if nyone else as noticed this. Has anyone done another quick bleed to see if this has helped?
    Regular Member vectrahunter's Avatar
    Feb 2007
    crosshouse
    After 2k miles the pads should be well bedded in .I would do a full system bleed and see if that improves the pedal.
    Nov 2007
    Lincs
    The thing is Ive only done 12k miles on the car so should i just buy .5ltr and do a quick bleed again or replace to better spec say Motul 600?
    Tyneside
    Found mine to be great since I fitted them(upgraded from 302mm)
    personally i'd swap the pads AND re bleed.. the 314's on cars i've swapped them on to are great brakes..it does sound like something is amiss.. if they still don't bite to your liking, there is the 345mm conversion option..
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Show off
    Jun 2007
    Sittingbourne, Kent
    something is definately amiss , i only have to tap mine
  1. cdti lacks power when cold, & engine light on
    By mr_dog in forum Engine & Drivetrain
    Last Post: 8th February 2010, 22:45
  2. Where's Your Clutch Bite Point?
    By AntB in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2008, 22:48
  3. Not as much bite in my gsi brakes as in 2.2dti elite...
    By RobDMX in forum Suspension, Wheels & Brakes
    Last Post: 30th April 2008, 21:22
  4. Clutch Bite Point....
    By Signum_CDTI in forum Engine & Drivetrain
    Last Post: 10th December 2007, 01:01
  5. Signum 1.8. lacks power,judders and surges!!!
    By mike56 in forum Engine & Drivetrain
    Last Post: 3rd July 2007, 15:58
