Thread: Vectra LS blowing cold air only
    carmarthenshire
    Default Vectra LS blowing cold air only
    Hi
    My 1.8 LS is blowing cold air only and i`m freezing going to work on a morning - any body had this one before or no what it is - i`m pretty useless as far as cars go but suspect a thermo or matrix but not sure where they are on the Vectra only had the car for two month still under warranty but if its something silly would rather sort it my self.
    Cheers andy.
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    How far you travel ???
    carmarthenshire
    Hi Gr4eme,
    I travel about six miles to work.
    Regular Member vectrahunter's Avatar
    Feb 2007
    crosshouse
    might be the heater control valve thats jammed shut
    as the cars got warranty take it back and get them to fix it
    11 Post(s)
    http://forum.vectra-c.com/showthread.php?t=54271
    http://forum.vectra-c.com/showthread.php?t=36766
    http://forum.vectra-c.com/showthread.php?t=41212
    http://forum.vectra-c.com/showthread.php?t=18433
    They all pretty much point to the same thing - A faulty servo that is accessed by removing the glovebox.
    That is of course providing the temperature gauge is actually reading hot. If not, then it *might* be a faulty thermostat.
    carmarthenshire
    Cheers BD
    Yer the temp gauge looks pretty normal after a few mins warming up - i`ll check this out tomorrow - Day off
    Cheers andy.
    runcorn
    My vectra 05 only blowing cold air aswell , changed thermostat took glove box out checked red arm, moving ok when turning dial to hot & cold, added coolent but still no joy anyone any ideas
    Regular Member no1baggiesfan's Avatar
    Jan 2008
    Newcastle
    Vehicle : 1.8 VVT SRi
    If it was a diesel I'd say that was normal lol, my 1.9cdti takes ****** ages to warm up.
    Blocked heater matrix ? (if there is one) that was a problem on my old astra, attach a hosepipe to hot tap and one end of matrix, leave other side of matrix open and leave it running for 30 mins. thats IF lol.
    runcorn
    Thanks No1baggiesfan, tried your suggestion still no joy, noticed water doesn't seem to be circulating , think pump might be knackered could this be the problem ? doin my head in now fed up and cold
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    With the engine running from cold open the expansion tank and look down inside it, you should see water returning into it. Also after a good run the bottom radiator hose, it should be hot, if your not seeing either of these then best getting the pump checked out.
  1. Air con blowing cold
    By malcwit in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2012, 13:37
  2. Aircon not blowing cold
    By Ralphwells1967 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th September 2011, 22:38
  3. Heater only blowing cold air
    By Chilie in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2009, 18:26
  4. Vectra C blowing cold air
    By 999bruno in forum Engine & Drivetrain
    Last Post: 19th December 2009, 12:40
  5. Heater blowing cold.
    By neilgsi in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2008, 17:48
vectra cdti 1.9 blowing cold air
56 vectra 1.8 climate control blows cold
vectra c heater blowing cold
