Results 1 to 10 of 15
Thread: Tow bar fitting
    West Midlands
    Default Tow bar fitting
    After a bit of help. want to fit a Towbar to my Veccy estate, Now I can do both fitting the bar and the electrics no problemo as I'm an auto electrician. Although to be fair I've only ever fitted one towbar before, on my Dads Xantia! Anyway, I keep seeing and being told that I need bypass modules etc etc. Does it make a dfference if I have twin electrics? Is there anything I need, other than a load of 7 core
    Regular Member vectrahunter's Avatar
    Feb 2007
    crosshouse
    for the 12n side of the wiring you need the relay and loom that plugs straight into the rear fusebox .get it from vx about £40 its all plug and play no hassle
    12s don,t know whats required
    hope this helps
    West Midlands
    Sorted, that should make the job easier
    Thanks!!
    Feb 2007
    crosshouse
    no problem m8
    West Midlands
    Am I right in thinking though I can just wire this up to the individual wire without causing problems?
    Regular Member gvec's Avatar
    Feb 2007
    scotland
    Quote Originally Posted by McLovinH View Post
    You will have to use a bypass relay for the 12n-DO NOT WIRE STRAIGHT TO THE LIGHTS WITHOUT GOING THROUGH A RELAY12s i always use a ryder switching relay wich only needs a 12v feed which you can get in the boot all availabe from towsure.HTH.
    Regular Member daneboy35's Avatar
    darvel,ayrshire
    You cant wire straight from the original wiring because theres a dual voltage at the rear lamps,tail-lights are only 4-5 volts iirc so it wont work your caravan/trailer lights
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    That can't be right can it? or you would need different voltage bulbs. Wiring it into the existing loom mainly affects the bulb failure circuits doesn't it? Having said that, it would only affect it when connected - depends how much you tow I guess. I did it that way in a previous car but only towed infrequently for trips to the tip etc so didn't mind having the bulb failure on all the time.
    West Midlands
    Pretty sure mine doesn't have a bulb failure system on though. Not sure about the voltages though, as surely they'd have to use different types of bulbs, as there wouldn't be enough juice to illuminate them properly. Ah well still looks more hassle than it's worth, wait for a call back from the stealers to see how much the loom is!!
    Regular Member D4M0's Avatar
    May 2008
    wigan
    most of the bulbs i think all the bulbs are 21 watts and the car controlls the voltage to them this is so eg: if a brake ligh bulb goes the car will send more volts to the side light bulb so u always have a brake light or fog,i no it does it on bmw's etc i asume it applys to vx's. i did a signum towbar and fitted a 7 way bypass relay and a split charging relay all from towquipe
  1. hid fitting
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2011, 18:25
  2. USB fitting
    By chinarose87 in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2010, 17:21
  3. When im fitting
    By PAULMAC77 in forum Styling
    Last Post: 3rd April 2009, 15:30
  4. fitting a PS2
    By steeb82 in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2008, 09:30
