Thread: 1.9 CDTI Engine Change
    Oct 2007
    Ripon
    Default 1.9 CDTI Engine Change
    What would it cost to exchange the engine - minus the cost of replacement engine?
    In the Nort East / Leeds area
    Regular Member benny's Avatar
    Feb 2006
    dudley
    why mate what ya done to ya old lump ?....
    as a rough guide and trust me its rough ... aprox 8 hours ..so depending on ya labour rate ...say £80 ...8 x £80 ...plus the dreded ..plus fluids and filters and aircon regas ...so a fair bit ...but it all depends on labour rate and if the people fitting will do it for a set price ...
    Feb 2006
    dudley
    Yorkshire
    The average labour rate for a smaller garage is about £20-25 per hour.
    So I recon your going to be in the range of £500-600 assuming its a straight forward job.
    I depends on how much stuff is going to need transfering from one block to another ie clutch, turbo, alternator, AC pump etc. I'd recon on it taking 2 full days but expect the car gone for at least a week.
    If your not in a rush you may be able to get a better hourly rate.
    Also consider when fitting an engine is it worth putting a clutch in while the gerbox is off and it a good ideal to do the timming belt if it has one.
    It took me 8 hours to get the automatic gearbox off mine!
    It would have been quicker for me to remove the engine and gearbox as one and strip them down out of the car I think but I just don't have the space.
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. How often do you change your engine oil?
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2011, 13:32
  3. change my engine!!!
    By bedo13 in forum Tuning
    Last Post: 28th July 2010, 23:50
  4. 1.9 cdti Engine change
    By user999998 in forum Engine & Drivetrain
    Last Post: 17th September 2009, 16:47
  5. engine change
    By yadziyad in forum Diesel Engine related
    Last Post: 22nd May 2009, 20:38
