can any1 tell me if the vx badge in the centre of the boot lid is just held on with sticky pads or are there holes in drilled under it?????
Easy to remove, just takes a while to remove the stickyness left behind! Bug and Tar remover
Yeah, so so easy.
Get a hair-dryer on it, and some gentle prising takes it clean off.
You can remove the glue underneath with the same hairdryer and the edge of a credit card.
A bit of t-cut and you can't ever tell it was there.
Same with all the other badges.
wicked that should keep me busy for a couple of hours tonight
easy peasy..........warm water and the best method is fishing line and ease it off....if no fishing line then a credit catd will do.....then some sticky stuff remover ...like tar and bug remover to get the glue off...
Did not 100% work for me:
http://forum.vectra-c.com/showpost.p...1&postcount=10
i have to admit that looks sooo much better without the badges... cheers guys.
