Thread: New door pins, fitting help
    Regular Member Andy17899's Avatar
    Jun 2007
    West Midlands
    Vehicle : Vauxhall Vectra SRI XPII
    Mileage : 68K
    Default New door pins, fitting help
    I just bought some new door pins, have got the old ones off, and the new ones on, but i tighten the allen key up all the way and it just isnt even close to gripping the threaded rod...
    Any ideas?
    Btw, its the cheapo ones, with the two bits of rubber a the top.
    cheers
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    keep tightning or use some mastick and leave to dry over night
    Jun 2007
    West Midlands
    Mileage : 68K
    Ive tightened it as much as it will go mate and its nowhere near gripping it
    lanark
    5 Post(s)
    Year : 2012
    Mileage : 9k
    sounds like the little grub screw is not going through enough it may be on the wrong thread but if they are all like that i would have used some mastik as long as you dont need to get them back off
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    They sound the same as mine and mine fitted fine. Got mine from LMF
    Jun 2007
    West Midlands
    Mileage : 68K
    might use some mastik, but it might run down the thread?
    Here, there and every where!
    On the cheaper ones when the grub screw hole is drilled and tapped it leaves a small burr on the inside and it stops the bar going all the way inside.
    Easiest way is to get an allen key the same diameter as the hole and push it in to the door pin as far as it will go and twist it until it will not go any further. It should just remove the burr and allow the pin to sit lower and you can then tighten the grub screw on to the bar.
    Regular Member cornishpirate's Avatar
    Cornwall
    I have a set of these 'cheapo' ones and they went on fine
    Are you tightening the upper or the lower allen key? I used the lower one and it was right down bythe edge of the door card so was a real git to get at.
    You may also have to trim the bottom off the rear ones to allow them to go down enough to be level with the front ones as the locking bar has a bend in it just inside the door card and this stops the pins from going all the way on.
    Catermans advice on clearing and burrs should make sure the holes are clear but to state this obvious make sure you undo the grub sceww before you put the allen key into the main hole
    Jun 2007
    West Midlands
    Mileage : 68K
    lol yeah thanks mate, i have go tone through but the others wont budge, allen key or not, im tempted to drill and re tap them, or to glue them on... hmmm
    Jun 2007
    West Midlands
    Mileage : 68K
    well, after a lot of drilling and threading, they are on and look cool, cheers for your help guys
  1. Richbrook Door pins fitting problem.
    By crespo in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2010, 10:36
  2. Door Pins (Fitting)
    By Lee.. in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2008, 13:55
  3. Door Pins - Will these fit my car?
    By sduk in forum Styling
    Last Post: 31st July 2008, 20:59
  4. Fitting door pins
    By Baz07 in forum Bodywork & Interior
    Last Post: 20th April 2008, 21:18
  5. Door Pins Again ...
    By Bainie in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2006, 22:59
vauxhall vectra door pins
door pin vectra c site:www.vectra-c.com
