Results 1 to 10 of 18
Thread: is it possible to change 2.0 dti turbo to 2.2dti turbo
    Regular Member EURO G's Avatar
    n ireland
    Default is it possible to change 2.0 dti turbo to 2.2dti turbo
    i have got my hands on a very good 2.2dti engine and was wondering would changing to the bigger 2.2dti turbo give my 2.o dti more bhp and is there any draw backs to swapping them over
    It'll be about an extra 20/30 bhp mate, no idea about the ins and out though,
    Belfast
    2.2DTi uses a totally different turbo, it's a varible vane unit compared to the bog standard type of the 2.0. While you could probably fit the 2.2's turbo, you'd probably have to get some sort of reprogramming on the ECU to cope, if it's at all possible.
    If you've got the whole 2.2DTi lump, why not fire that in? It's got to be easier that starting to fart about swapping turbos.
    n ireland
    ive got the whole block we bought it today to get feul pump off it some scrap yard give us whole engine seems like theres only 20k on by the looks of the engine internals etc i presume my fuel pump would be compatible with the 2.2dti as thats the only part we used from new engine how much bhpwould i get from just replacing turbo and could a diagnostic machine sort out the reprogramming
    Belfast
    Hmm...doubt a diagnostic would do it, you'd probably need to give someone like Dave Wishart a ring and see if he could help - he does some fancy remapping with hybrid turbos etc.
    Not sure if the pump will be the same - they're probably physically the same, but you'd probably need to check the ident number etc.
    I don't think it's a 2 hour job to get that thing going...
    n ireland
    zs could i have the number of that guy if possible as i was thinking of getting the 2.0 remappedd and then if it goes bang throw in the 2.2 lol
    n ireland
    anyone else shed any light on the subject
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    First dibbs on ya 2.0 lump lol
    n ireland
    the way things r going you could have the 2.2 lol
    May 2008
    Widnes.
    I take it that its not easy to swap then ?
  1. 2.2Dti turbo gone
    By jono_c in forum Engine & Drivetrain
    Last Post: 29th August 2012, 10:09
  2. 2.2dti oil around turbo area
    By wads187 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd May 2012, 10:46
  3. 2.2dti turbo screwed?
    By Innes in forum Engine & Drivetrain
    Last Post: 28th February 2011, 13:04
  4. Squeaky turbo on 2.2dti
    By dnl_303 in forum Engine & Drivetrain
    Last Post: 5th October 2009, 19:17
  5. Someone Help!!! 2.2dti Turbo......
    By chairman_miaow in forum Engine & Drivetrain
    Last Post: 30th December 2008, 15:42
2.2 dti turbo on 2.0 dti
how to change a turbo on a vauxhall dti 2 litre
vauxhall astra 2.2 dti conversion
zafira dti turbo conversion
dti 2.2 conversion
2.2 dti in to a zafira conversion
2.2 dti turbo 2.0 dti
vauxhall 2.2dti turbo
vectra 2.2 dti swap
can you replaxe 2.0 dti turbo with 2.2
vectra are 2.0 an 2.2 turbos the same
2.0 dti turbo
2.2dti turbo conversion
2.2 dti to 2.0
swap turbo vectra dti
