Thread: Vectra CDTI Advice.
    Blackpool
    Default Vectra CDTI Advice.
    Hi.
    I have seen a 04 Vectra SRI CDTI [150]. Its done 99k with full Vauxhall History and its just had the DMF and pressure plate done aswell, The car is from a garage and its up for £4100 ONO.
    What do you guys think?, I know Dervs can go much longer than petrols, But is it to much. I do about 8k per year.
    Luke
    Belfast
    If you're doing 8k a year, you're mad buying that car. Has the inlet manafold been done? Same with the EGR?
    Get a younger 1.8, you'll get similar MPG, it'll be cheaper to insure.
    I'm doing 20k a year and it's going to be cheaper to run a 1.8 Vectra than it was the 1.9CDTi Astra I had before.
    Blackpool
    Am not sure what else has been done.
    Does the inlet manafolds often fail?, Can you take the EGR out on this cars?. My mates PD engine you can.
    Whats most the common things to fail on this cars?.
    I do some towing with a tailer and my two race bikes, So want something with some power, Plus after a remap there gonna be quicker than the 1.8.
    Luke
    Belfast
    The manafold almost always fails, and you're looking £500 at least to get it changed. EGR can't be blanked or removed unless you like lumpy running and the EML lit all the time. The EGR clog up quite easily if you're doing low or city mileage.
    If you want power, then the 2.0T is your best bet for reliable low milage.
    Blackpool
    What about the 2.2 models?. Seen a nice 03 SRI 2.2 with full leather, 80k for £3500.
    What sort of mileage do the 2.2 models do.
    Luke
    Belfast
    2.2 is a bit thirsty, the 2.2Direct is the better engine, it gets about 1mpg worse than the 1.8VVT. 2.2 is about 150hp, 2.2Direct is 155hp I think.
    2.2Direct has a 6 speed box in the facelift, though they're probably a little dear for what you're looking to pay.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Quote Originally Posted by PLuKE View Post
    Hi.
    Luke
    To be honest, it sounds a relatively good buy, with a bit of haggling you'll be able to get yourself a bargain mate.
    With the DMF done, thats the most expensive thing done, and you'll have a 50/50 chance of anything else failing (like any other car on the planet) so if straight enough, then why not..?
    Regular Member solorider's Avatar
    swindon
    Engine : 1.9 120bhp
    Mileage : 139,600
    i have just bought a 04 1.9cdti for £3995,i paid an extra £215 for a years warranty and mine has 107k miles on it,is a design estate and has factory fit 18" wheels so i also get sri suspension as well,the dmf is a rework and it is recommended to take a drive for about 15 minutes and keep the revs above 2000 for the dpf to regenerate,also a good excuse for a good thrashing once in a while lol,i dont do a lot of miles but having a diesel still saves me money over a petrol,and a 1.8 will not pull like a 1.9 diesel
    here is the car i bought
    Blackpool
    I have seen a few cars about. Another was a 04 1.9 CDTI SRI with 108k on the clock for £4200, But am sure i could knock him down some with cash only. Its comes with 6month AA parts and labour warrenty. The car does look in very good condition as its just been used for motorsways.
    A Derv is what am after TBH, As i like the low down power and fuel when traveling.
    Any other things i should look and listen out for on this cars?.
    Luke
  1. Help & advice please vectra cdti
    By ONEMINUTESILENCE in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2010, 12:15
  2. Buying Advice for Vectra C facelift SRI Model CDTI 150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2010, 20:56
  3. Need advice/diagnosis re 57 plate Vectra 1.9 CDTi 150
    By TrcikyD in forum Engine & Drivetrain
    Last Post: 21st May 2010, 17:25
  4. Vectra 1.9 CDTi advice
    By GenVectra in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2009, 04:37
  5. Vectra 1.9 CDTi buying advice..
    By Faz in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2007, 01:07
