Hope this is in the right place!
Recommended torque values (Y 20 DTH, Y 22 DTR)
Nm
Exhaust manifold to turbocharger
30
Exhaust manifold to cylinder head
221)
Front exhaust pipe to return manifold
201)
Axle shaft to wheel hub
1) 2)
Starter to cylinder block
40
Receiver-dryer to radiator
4
Cover of balancer shaft unit to balancer shaft unit housing
20 Nm +30° 1)
Oil filter housing cover to oil filter housing
25
Cover (oil pump) to timing case
8
Timing case cover (injection pump) to timing case
6
Torque converter to drive disc
603)
Duplex chain tensioner to timing case
60
Intake manifold upper part to intake manifold lower part
8
Lower part of intake manifold to cylinder head
221)
Injection line to injection pump
30
Injection line to traverse injection nozzle
30
Injection pump to main bracket
20
Injection pump to cylinder block
25
Transverse link guide joint to steering knuckle
30 Nm + 60° + 15°1)
Balancer shaft unit guide rail to balancer shaft unit
9
Duplex timing chain guide rail to cylinder block
8
Simplex timing chain guide rail to cylinder block
81)
Alternator to alternator bracket (coolant flange)
35
Transmission to fluid pan (M10)
40
Transmission to cylinder block (M12)
60
Sheathed glow plug to cylinder head
10
Compressor bracket to cylinder block
35
Injection pump bracket to injection pump
20
Fuel injection pump bracket to cylinder block
20
Alternator bracket (coolant flange) to cylinder head
20
Rear engine damping block bracket to transmission
80
Rear engine damping block bracket to rear engine damping block
80
Oil intake pipe bracket to oil pan
8
Starter heat shield to starter
6
Heat shields
8
Crankshaft pulse pick-up to cylinder block
8
Refrigerant line to receiver-dryer
20
Refrigerant line to block connector (separation point)
20
Refrigerant line to compressor
20
Ribbed V-belt pulley to coolant pump
20
Crankshaft ribbed V-belt pulley to crankshaft
150 Nm +45° +15°1)
Ribbed v-belt tensioner to compressor main bracket (M8)
20
Ribbed v-belt tensioner to compressor main bracket (M10)
42
Balancer shaft unit chain tensioner to balancer shaft unit
9
Fuel line to injection pump
25
Lower radiator bracket to front axle body
35
Coolant pump to timing case
20
Coolant pipe to cylinder block
35
Crankshaft bearing bridge to cylinder block
20
Crankshaft bearing cap to cylinder block
90 Nm + 60° + 15°1)
Intercooler to radiator
4
Upper charge air pipe to cylinder head cover
3
Fan housing to radiator
4
Upper engine cover to cylinder head cover
8
Rear engine damping block to front axle body
60
Left engine damping block to left engine damping block adapter (F 35)
55
Left engine damping block to transmission (F 23)
55
Left engine damping block to body side member (M8)
20
Right engine damping block to body
55
Right engine damping block to right engine bracket
55
Front engine damping block to transmission
80
Front engine damping block to front axle body
80
Right engine bracket to timing case
55
Engine transport shackle to cylinder head
20
Camshaft bearing caps to cylinder head
131)
Camshaft sprocket to camshaft
90 Nm + 60° + 30°1)
Oil drain bolt to oil pan
10
Oil pressure switch to cylinder block
30
Oil filter casing to cylinder block
20
Oil dipstick guide tube to cylinder block
8
Turbocharger oil return line to turbocharger
8
Turbocharger oil return line to cylinder block
20
Oil intake pipe to oil pan
8
Oil spray nozzles to cylinder block
22
Turbocharger oil feed line to turbocharger
20
Turbocharger oil feed line to cylinder block
20
Oil pan to transmission housing (M10)
40
Oil pan to timing case (M8)
20
Oil pan to cylinder block
20
Pedal sensor to bulkhead
9
Swing arm to spring strut supporting tube
651)
Con-rod bearing cap to con-rod
35 Nm + 45° + 15°1)
Wheel to wheel hub
110
Intake pipe (throttle valve module) to intake manifold upper part
8
Hose clamps for air intake and charge air hoses
3.5
Flywheel to crankshaft
45 Nm + 30° + 15°1)
Dynamic oil level control sensor to oil pan
8
Coolant temperature sensor to cylinder head
10
Charge pressure sensor (intake pipe pressure sensor ) to intake pipe (throttle valve module)
8
Oil temperature sensor to oil pan
18
Simplex injection pump sprocket to injection pump
28
Simplex chain tensioner to cylinder head
60
Tie rod to steering knuckle
351)
Timing case to cylinder block
20
Exhaust manifold support to exhaust manifold
25
Exhaust manifold support to cylinder block
25
Starter support to starter
7
Starter support to cylinder block
25
Thermostat housing to cylinder head
8
Injection nozzle traverse to cylinder head
4)
Return manifold to turbocharger
301)
Ribbed V-belt guide roller to support
35
Switchover valve vacuum unit to lower part of intake manifold
8
Vacuum pump to cylinder head
8
Compressor to compressor support
22
Condenser to intercooler
4
Oil pressure regulating valve closure plug to timing case
40
Pressure relief valve closure bolt (oil pump) to timing case
30
Supply unit (electro-hydraulic steering) to body
22
Reinforcement plate to body (M10)
55 Nm + 45° + 15°1)
Reinforcement plate to body (M12)
90 Nm + 45° + 15°1)
Rear of front axle body to body (M12)
100 Nm / 74 lbf. ft. + 90° + 15°1)
Front of front axle body to body (M12)
80 Nm + 120° + 15°1)
Heat exchanger to oil filter housing
20
Intermediate shaft to steering gear
22
Cylinder head to timing case (M8)
20 Nm + 30° + 5°1)
Cylinder head to cylinder block
25 Nm + 65° + 65° + 65° + 65° + 15°1)
Cylinder head cover to cylinder head
8
1) Use new fastening nut/bolt.
2) Tighten axle shaft nut to 150 Nm. Then release axle shaft nut by 45° and retighten to 250 Nm.
3) Use new bolts and retaining compound
4) Hand-tighten new fastening bolt using torx nut and extension (without toggle or ratchet), then turn fastening bolt a further 360°. Only this tightening procedure ensures that injection nozzle transverse is correctly tensioned on injection nozzle.
