Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: TC Switch
    Cambridgeshire
    Default TC Switch
    I have a question about the traction control switch. I was looking over the beginners modding bits and it says that most Vectra's have the wiring behind one of the panels to just clip a switch into.
    I haven't checked this yet on mine but if it has the wiring and i fit it will the switch actually work? Or is it there for show?
    May 2008
    St.Albans
    Worked for me.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    luck of the draw mate, mine has the wireing but doesn't work just illuminates which is nice...
    Midlands Mod Shop - NFFC.
    Cambridgeshire
    I might try it then. I'm guessing it'll be obvious if the switch works or not?
    May 2008
    St.Albans
    Light come on the dash when you press the TC switch, basicly turning it off, on speeds lower than 35mph IIRC.
    East Midlands
    Works on my 03 2.0dti...when you remove the blank,if you see a blue plug like mine...http://forum.vectra-c.com/showthread.php?t=56422.. then its odds on it'l work...can't wait till it snows so i can compare it to how the car reacts with it switched on and then off.
    Tyneside
    Quote Originally Posted by Impresss View Post
    It can only be switched off when travelling below 40mph, but can be truned off whenever you like
    Regular Member gogs37's Avatar
    inverallochy
    it worked for me 2.2 sxi
    Cambridgeshire
    So you can have it on or off at any speed you like but you can't turn it off if you're going above 40mph?
    Tyneside
    Quote Originally Posted by parsco View Post
    Yep can be on or off at any speed, but you can't turn it off above 40mph for some reason. You can turn it off below 40mph and it will stay off until you choose to switch it back on. Hope you understand what I'm saying mate LOL.
  1. Small 12v Auto circuit for on/off switch for PDC switch
    By markm in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2012, 23:00
  2. Clutch Switch & Brake Switch
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2011, 12:01
  3. headlight switch window switch in blue
    By delboy2028 in forum Parts for sale
    Last Post: 26th May 2010, 08:56
  4. t/c switch help
    By kitchcav in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2007, 18:02
