Thread: When should you replace shocks?
    Regular Member addyboy1982's Avatar
    Northampton
    Default When should you replace shocks?
    I've been going back through the car's maintenance print out today to see when various bits were last changed, discs were done not too long ago (phew) but the car seems to be on its original shocks - do they have a 'normal' lifespan? Car is 4.5 years old now....
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    shocks do get worn,on the vectra c that would show as a knocking when going over bumps (make sure the rear bushes are ok first though) and this can happen anytime usually after about 50k sometimes earlier hence why the rear shocks have a shorter warranty than the rest of the car,they can loose their damping properties over time but most people only change the rear shocks when they start to leak,usualy when the mot is due
    Jul 2006
    Mexico
    When you feel your car is loose and tries to have a life of its own on the curves
    May 2006
    scotland
    When its an MOT failure
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Give them check for oil leaks and poor bounce. Rears are easy to change along with the rear arms. UR welcome to come round and I can check them and help u change the rears if needed
    Northampton
    Quote Originally Posted by merikiito View Post
    Cheers Lee I may just take you up on that. I'll have a look when I'm back home later on and see. It's due an oil and filter next week, so if the garage report that they're starting to get a bit tired, then I may just go the whole hog and get it lowered on new springs too
  1. Going to replace my rear Shocks/Springs
    By Jonsey in forum Handling & Braking
    Last Post: 12th July 2013, 23:50
  2. Can i rip out and replace?
    By bbdp in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2012, 11:17
  3. How to: replace front shocks for Vectra C
    By SeeDeeXeye in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2010, 00:25
  4. Should I replace my shocks??
    By spatch in forum Handling & Braking
    Last Post: 28th August 2008, 16:17
  5. Replies: 39
    Last Post: 26th July 2008, 22:40
