Thread: Will this fit a vectra??
    Regular Member ROY2593's Avatar
    Caernarfon,North Wales
    Default Will this fit a vectra??
    Hi,
    Will this fit a vectra 2008?? or just the knob even??
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...ayphotohosting
    Many thanks,
    Roy.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    should be a straight fit m8
    May 2008
    UK
    as glynn said it should fit
    i got a vectra vxr one which looks the same as that & went straight on my 1.9 cdti, plus is a load nicer than the std one
    piccy
    Not sure if the bottom piece is with it, would i need it to fit to the car or would it be on the vectra already?
    May 2008
    UK
    Quote Originally Posted by ROY2593 View Post
    no mate you don't need the bottom piece, when i fitted mine i removed that part - under the leather gaitor are a couple of torx bit screws - just take them out on your existing setup, and take off old gear knob complete with gaitor, and refit with with vxr one job done, takes literally 5 mins, in-between tea breaks naturally
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    i was told you need the shaft with the knob as the knobs in normal vectras have a different way of putting it in to reverse??? i could be wrong
    Regular Member solorider's Avatar
    swindon
    Engine : 1.9 120bhp
    Mileage : 139,600
    Quote Originally Posted by vectragsi3.2 View Post
    my cdti has a 6 speed box with reverse in the same place as the knob for sale
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
