Thread: Replacing rear shocks
    Regular Member Marc 100's Avatar
    Nov 2005
    Berks
    Default Replacing rear shocks
    I've read the how 2 (as I'm no mechanic at all) but I'd like to know if any of the suspension components need supporting in any way before removing the old shock?
    Also, is it a straight swap over (I've bought Bilstein B4) or does the new shock need compressing to fit first?
    I've found the top torx bolt easy to slacken off but haven't managed to shift the bottom one yet as it faces inward and access is tricky.
    Would appreciate thoughts from people who have done this job.
    Thanks.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    just jack the car up on the jacking point remove the wheel and just undo the to bolts and its a straight forward replacement
    Regular Member Figgz's Avatar
    Gothenburg - Sweden
    It's no problem with the lower one, just apply some force And the suspension will not need support, but if you want to feel secure so place the jack under the suspension (below the spring).
    Good luck! E18 and E20 torx are needed iirc
    Jan 2006
    carlisle
    Default shocks
    not difficult but its tricky to get enough leverage on the bottom bolt when torquing up- i was about 20 n/m short
    but nothing has fallenn off yet...
  1. Help replacing rear bumper
    By JAY6390 in forum North Wales (RO - vacant, ARO vacant)
    Last Post: 26th November 2012, 12:56
  2. Replacing new front shocks. What else?
    By Marky in forum Handling & Braking
    Last Post: 20th August 2012, 15:14
  3. When replacing shocks and springs....
    By Kev_A in forum Handling & Braking
    Last Post: 2nd June 2012, 17:28
  4. Replacing rear light cluster
    By Tullow_Vec in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2011, 22:38
  5. Replacing Rear Pads Dilemma
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2011, 20:24
