Thread: Wierd Problem with Key / CL
    Birmingham
    Default Wierd Problem with Key / CL
    I have realised that sometimes the car doesnt open straight away and the open button on the fob needs to be pressed a couople of times for the car to respond. Also...usually to lock...i press the fob once for locks to close down and then press again for the extra secure lock (i thinks its called dead lock or sumthing where its unable to open from the iside...car makes a locking noise but you cant see anything move on the doors)...we'll recently the key doesnt do that...just once for car to lock...and if i press it again nothing happens at all. If i mess around a few times open and lock the car, sometimes from inside somtimes from outside...eventually it may allow me to do the double lock.....What could be wrong.
    tried reseting by turning the ignition till dash lights up and then pressing the fob buttons..but there was no response at all when i done this.
    could this also be causing my starting problems...i.e immobiliser issues??
    Admin plasma's Avatar
    On the Forum
    325 Post(s)
    Engine : 150
    Mileage : 74000
    possible low battery in the remote key, suggest try another one mate.
    Jul 2006
    Mexico
    either the battery on the fob or somehow the botton switches on the fob are dirty, which is less probable do that the fob is pretty well "sealed".
    HTH
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    what they both said m8 try replacing the battery to see if that does the trick
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Quote Originally Posted by shatz View Post
    Not being able to lock or unlock the car with the key is not linked to the immobiliser - there's a small, non-powered chip in the key that's read by the ignition barrel.
    It's most likely a weak battery that's causing the key issue.
  1. wierd problem
    By ste_goffy in forum Engine & Drivetrain
    Last Post: 16th December 2009, 01:01
  2. Some Wierd Stuff
    By Tadpole in forum The 'Off Topic' room
    Last Post: 8th August 2009, 22:10
  3. Wierd Climate control problem
    By David2452 in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2008, 17:06
  4. Its a wierd one but need help!
    By Kyser143 in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2008, 21:29
  5. Wierd Startup Problem
    By Cheeky_B in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2005, 10:12
