Thread: cdti 150 engine power below 1500rpm
    Regular Member solorider's Avatar
    swindon
    Default cdti 150 engine power below 1500rpm
    my 2004 vectra cdti 150 is very flat below 1500rpm,you can put your foot down and a milk float will leave you standing,once 1500rpm is reached the speed picks up a lot better,at 2000rpm it takes off like a scalded cat,is this normal or is the flaps in my inlet manifold seized? if so can you clean the manifold without taking the cambelt etc off? there is no eml lights on
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Pretty much normal... My 150 has little power until the turbo comes in at 1450 its as flat as a pancake until that turbo kicks in. You should have pretty much full power available well below 2000 however. 1500 is where the touch paper gets lit and the rocket takes off.
    swindon
    sounds like mine is as it should be,mine has nothing below 1450 then it picks up a lot faster,at 2000rpm you get the full torque and you certainly feel it,im still trying to get used to it as my audi tdi was a bit more torquey at very low revs,many thanks
    member of the smoke patrol 230bhp+
    this is normal
    it only that your revs are so low your not getting a lot of boost from your turbo "" turbo lag "" and as long as its starts picking up from around 1500 rpm things sound to be all fine
    Regular Member VectraV6CDTi's Avatar
    Wilts
    I found this when I test driven one for a few days and it was one of the reasons that put me off the 1.9 CDTi. It catches you out the first time you drive it but I think you'd get used to it. My 3.0 is a lot different in comparision, pulling all the way from 1000rpm. These are my thoughts when I test driven a 1.9 CDTi a couple of years ago, before I bought my 3.0.....http://forum.vectra-c.com/showthread.php?t=11196
    Apr 2008
    In UK
    Quote Originally Posted by VectraV6CDTi View Post
    I agree.... this is one of the big things I dont like about my car, I remember when I first had it, many times I caused embarrasement to myself when the car did not want to move beyond snails pace when I needed to move quickly like pulling out at junctions or Islands etc. AYS you do get used to it and of course you make sure those revs are up when you need to get away quickly, though occasionally I still forget to raise the revs when pulling away and it just die's on me. (never been my nature to unduly rev a car...lol)
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Yep turbo lag. Perfectly normal. The 1.9CDTI diesels' turbos seem to take longer to spool up to the point at which the horses are let go, which is supposedly just shy of 2000rpm. The petrol turbo Vectras don't seem to have the problem even though in the case of the 2.0T, they let their horses go a bit later than the 1.9CTDI's but pull well from 1100 revs.
    May 2006
    scotland
    As everyone has said, normal but once you have adapted your driving style, it shouldnt cause you any problems IMO. Get a remap or tuning box for loads more fun above 2k revs.
    Apr 2008
    In UK
    What I like about the diesel vectra is the fact its a brilliant motorway car, I do a lot of long run motorway journey's including regular trips over to western France and its so economical, and a really quiet and smooth drive, thats when that 6th gear really comes into its own.
  1. Miss fire at 1500rpm on my 120 cdti
    By rob10 in forum Diesel Engine related
    Last Post: 29th June 2013, 23:37
  2. 3.0CDTI V6 1500rpm engine judder - Facelift??
    By doncaster_mainline in forum Engine & Drivetrain
    Last Post: 11th August 2012, 15:25
  3. No Power below 1500rpm
    By stuart813 in forum Engine & Drivetrain
    Last Post: 29th July 2010, 21:18
  4. vectra cdti slight miss at 1500rpm
    By kamar in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2010, 01:12
  5. 1.9CDTI power dip at 1500rpm
    By helisurf in forum Engine & Drivetrain
    Last Post: 13th November 2009, 12:50
