Results 1 to 10 of 11
Thread: rear suspension
    Feb 2006
    Dorset
    Default rear suspension
    How do you know when its mullered ??? mine now feels like a 20 year old shogun on cart spring suspension , it doesnt make any odd noises and the tyre wear is pretty normal , but the back end feels detached .
    tempted to throw it at the dealer and get SRI stuff shoved on ,
    looks a mess but pulls like a train still
    East Midlands
    Quote Originally Posted by DennisTheMenace View Post
    ?Are you still running with the OE rear shockers..if so then it's allmost certain they are the culprits..even if they are not showing obvious signs of wear..leaks etc.
    Feb 2006
    Dorset
    the shock were changed at the 60k service IIRC but it is still very soft , and if i do hit a bump i can feel the wheel "bouncing" i cant see new shocks failing in 13k though ?
    East Midlands
    You say they were changed at 60 k m8..?what did you get put on then make wise...cus wheel bounce is odds on rear shocks.
    Feb 2006
    Dorset
    Replacement OE shocks mate , thae car carries a lot of weight in the boot , im tempted to get SRi stuff fitted if i can , last pressie for the old girl before she retires , she is overdue now , but im waiting for the insignia as it might be coming on the co car list ... if not im going prius !!!!
    East Midlands
    That says it all then bud..the oem ones are garbage..as per justification from lots of members on here,who have changed to mostly billstein b4s including myself..as i had the same probs as you,with rear end bounce and step out,and my old ones had only been on the car for 20 thou apparently..if i were you for the sake of £80,i'd start with them..but then again if your selling soon then why bother.
    Belfast
    Vauxhall shocks are rubbish, plain and simple. I've never got more than 50k out of a set. Either replaced with Bilsteins (EuroCarParts are your friend for those), or some sort of suspension kit. Last car had a Bilstein B12 kit, but it was a little lumpy for my liking unless you were doing about 90.
    If you plan on keeping the car a long time, then Koni FSD are some job.
    Feb 2006
    Dorset
    I will be changing my car end of jan when i get back from south africa . im not spending my own money on it as its a co car , so it can go to the dealer again , i will push for sri shocks and springs .
    Jan 2008
    Tyrone
    Hi mate!
    My left rear spring was snapped and the shock had about 10mm (yes 1cm!) of movement in it when I replaced them last week!!
    Tbh, I had suspected for ages, it was just a case of funds as to when I would replace!
    There was this one dropped manhole that was on a bend near where I live, and the rear end would skip and twitch going round the bend whilst simultaneously trying to deal with the dropped manhole.
    If you find something similar, you can bet your rear shocks have had it!
    hth!
    Nick :-)
    New Member CDUB's Avatar
    London
    Quote Originally Posted by nickyg View Post
    Hi mate!
    hth!
    Nick :-)
    I have an 04 Vectra C, 3.2 GSI auto its done 43,000 and like MCDAD probs with rear end bounce and step. The shocks are originals. Surely its too early to change the rear shocks. ls it worth changing front and rear the anti roll bushes as well?
  1. rear suspension
    By leedavis1971 in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2012, 21:33
  2. Rear arm suspension
    By Sambor in forum Suspension, Wheels & Brakes
    Last Post: 30th May 2010, 10:37
  3. rear Suspension
    By Tom Tom in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2009, 00:11
  4. Rear suspension
    By nhoj in forum Suspension, Wheels & Brakes
    Last Post: 20th January 2008, 15:05
  5. Rear Suspension
    By Landroverdave in forum Suspension, Wheels & Brakes
    Last Post: 4th September 2007, 10:12
vectra suspension very soft
