Thread: Network Q Timing Belt
    Regular Member shadyone's Avatar
    Nov 2007
    Northants
    Default Network Q Timing Belt
    Have had my 54 1.8 sri a couple of months now any its going great. Was planning on having the timing belt and water pump changed in the next couple of weeks as its done 66k with no record of a belt change, but cant get a straight answer if a timing belt faliure would be covered under network q warranty. All they will say is the aux belt is not covered, wondered if anyone had made a claim on a timing belt, cheers.
    Belfast
    Aren't those belts 80k/8 years?
    I'd have it changed to be safe, I've found NetworkQ are good at wriggling out of repairs.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    they say to change every 40-60 thousand miles and if it goes, out of the miles spesified then it wont be covered under warranty best get it done fella some times they say up to 80.000 too
    cambs
    just got mine done at 50,000
    go to a local garage m8
    they will charge about £250
    vx will charge you £480
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    here is what is not covered http://networkq.co.uk/nq/morefromnetq/carsguarantee.do timing belt is not mentioned,if the belt was due it should have been changed before the sale of the car,if the belt was to fail and it was not due then network q should cover it as at that time it is not a "service item" and rarely does a belt fail first,usualy a roller fails first,the vvt engine has a simpler belt run so the belt does not get so stressed so it will last longer
  1. anyway to do the timing belt without timing tool
    Last Post: 15th December 2012, 18:47
  2. Timing belt
    By mcmpin in forum Engine & Drivetrain
    Last Post: 19th July 2012, 18:35
  3. Timing Belt?
    By Rab in forum Diesel Engine related
    Last Post: 5th May 2011, 20:14
  4. timing belt?
    By leonvectrac in forum Engine & Drivetrain
    Last Post: 28th April 2011, 19:02
  5. Timing belt
    By piggysteve in forum Engine & Drivetrain
    Last Post: 23rd March 2008, 05:07
