Thread: Wobbling gear Stick
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Default Wobbling gear Stick
    Hi Guys
    I have a 2.2 Direct 05 Plate and i have an annoying problem
    my gear stick is wobbly when i grab it it did not used to be like that only in the past few months and its starting to do my head in what parts would need to be replaced or can anything just be tightend up??
    Plymouth
    Apparently they all do that. It's how you change gear...Tee Hee
    Sorry couldn't resist that.
    Pull the gater off and have a pooky round underneath. You may be able to see what the problem is a bit clearer. Otherwise me being a numpty I wouldn't know.
    Apr 2008
    Liverpool
    haha i change the gear fine
    how does one take the gater off around the gear knob??
    Apr 2008
    Liverpool
    anyone else know how to tighten this up as its doing my head in.
    i have had a look around and it seems to be wobbling at the ball joint bottom of the gear stick and the gear linkages move with it
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    The ring surrounding the ball unclips and there should be 2 large o-rings above and below the ball inside the socket,it might be worth checking if they're still intact.
    Apr 2008
    Liverpool
    hi mate would that cause it to go wobbly?
    also how easy is it to replace them and put the thing back together?
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    I've got a 2.2 non-direct but the linkage should be same,the o-rings seem to be a cheap way of providing tension to the g/stick so if they've broken up you could get a loose g/stick.To get it apart is simple if you've got flexible fingers!,the cable linkage just pushes off the ball joints on the g/stick, the top of the socket has 3 legs which have to be unclipped then the top lifts off and the g/stick pulls straight out getting it back together is the same but in reverse,the best way to get the linkage together is to reach under the linkage and pull up,pushing down on the g/stick doesn't work,i know i tried for too long!
    Apr 2008
    Liverpool
    I will have a little look either tonight or on the weekend when i had a quick look before i could see a metle clip sticking out of the plastic thing that goes around the ball joint at the bottom of the Gstick is that one of the clips i have to get off?
    thanks for your advice mate
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    That metal clip is to adjust the cables,put the g/stick in reverse and that will push in locking the g/stick,the clips you want are part of the plastic socket and are pointing straight down,it's a case of releasing one then pulling upwards slightly whilst you release the others,otherwise they clip in again!,HTH.
    Apr 2008
    Liverpool
    thanks for you advice mate i will give it ago possibly tomorrow when im parked up so i hae plenty of time to try and put it back together haha
  1. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  2. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
