Results 1 to 10 of 14
Thread: Mystery cover
    Regular Member old cruiser's Avatar
    slough
    Default Mystery cover
    Guys, on the 2.2 (non-direct) there is an oval shaped cover on engine block/ head passengers side just to the left of the EGR valve held on by 2 x bolts, any ideas what's behind this as I appear to have a slight oil leak at the bottom of this, hope this makes sense!
    Cheers Pete
    slough
    BTW here's a link showing the cover I mean
    http://i149.photobucket.com/albums/s...s/IMG_1363.jpg
    Cheers Pete
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    i think its just a blanking plate
    have you tryed to remove it as their might be a rubber ring that has perished, or it just might need some high temp silicone
    Sunny Dartmoor
    slough
    Haven't tried removing it as yet, but will do I think.
    Cheers pete
    Feb 2007
    Glasgow
    Distributor would go there, if it was needed.
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    very easy,this is where the power steering pump would go if the car had normal power steering,on the vectra c and astra g both have electro hydraulic power steering so dont need an engine driven pump,and as vauxhall/opel changed the exhaust camshaft it means you cannot fit a vectra c 2.2 engine into a vectra b without work
    shunter can you please answer me this,why would an engine have a space for a distrubiter when it was designed with modern electronics? the dizzy died before this engine was developed lol
    Feb 2007
    Glasgow
    Quote Originally Posted by solorider View Post
    This engine is sold worldwide, in many different forms...
    Just like this...
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    Quote Originally Posted by shunter View Post
    Just like this...
    yes the engine is sold world wide,but none of them had a distributer,the engine in the pic has been highly modified with a aftermarket ignition system
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Yep the Vec b, astra cam has a little fitment to run the pump, square hole I think? You'll notice the fuel rails are different also, so are the intakes as there are different vac's needed.
  1. Air-con mystery
    By chewy71 in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2011, 16:32
  2. A bit of a mystery
    By watchman in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2011, 06:44
  3. Key Fob Mystery
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2010, 22:45
  4. mystery pic......
    By david.aka.judas in forum General Chat
    Last Post: 18th July 2010, 22:07
  5. 2.2 Rocker cover (types) - Intake cover removal
    By vectrasri03 in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2006, 20:27
