Results 1 to 2 of 2
Thread: Disconnecting Boot
    May 2008
    Doncaster
    Default Disconnecting Boot
    Hi,
    The plastic clip that holds the boot cables in position keeps coming loose everytime I close the boot. It's on the left hand side and you've got 2 of them, one holds on to the boot and one holds on to the chasis, it's the chasis one that's gone...
    I can see it goes down into the car and the one on the boot I've not taken off yet but is it easy to do?
    I was kinda hoping to buy a new one, un clip the cables, slide then through the tubing and then re-fit. Is it this easy or is it a hard one?
    Thanks guys!
    the trick is getting the cables back down the inside of the boot pillars... tape a 'draw' wire to them when you pull them back up.....then use that to bring them back down.. as for how to change it, you're more or less spot on....
  1. When disconnecting the car battery.......
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2018, 14:54
  2. Disconnecting the battery
    By badge25 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2007, 12:40
  3. Disconnecting Battery
    By Neil in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2007, 18:12
  4. disconnecting the battery!
    By carl bear in forum Electrical & ICE (including SatNav)
    Last Post: 26th March 2006, 22:17
