Thread: tyres and tracking/camber
    Southampton
    Default tyres and tracking/camber
    Hi all,
    I need to replace my front tyres (signum 1.9cdti 150) and the current set have worn down a bit too much on the inside of each tyre.
    I suspect the wear is due to slight camber misallignment or tracking - sound right to you guys? If so can anyone recommend somewhere to get it sorted in the southampton/fareham area?
    Also I'm looking for tyre recommendations - it had a new set of el-cheapos when I bought the car (originals needed replacing and I forgot to say replace with a "good" new pair) which are pretty much useless in the wet - although dry they are ok - So I'm looking for something which is good in the wet.
    Regular Member silverhairedracer's Avatar
    ESSEX
    If you get your new tyres from a decent supplier they should have a laser system for checking your wheel alingnment & camber,cost me about £50 to have done but well worth it you will notice the difference on the first corner you take.
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    You have got to get it laser 4 wheel tracked!, went to F1 auto centre, think they charged me £20 to check and £10ish for adjustment, i got my tyres there two for my mothers car.. well worth it......
    Maida Vale
    Quote Originally Posted by dv8 View Post
    I seriously doubt F1 checked or adjusted the camber, just alignment.
  1. tracking and tyres
    By fjaimo10 in forum Handling & Braking
    Last Post: 28th September 2011, 21:49
  2. 50% off Tracking & Free Puncture repair at National Tyres
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2010, 22:43
  3. tracking and camber adjusting
    By cookiejar31 in forum Handling & Braking
    Last Post: 10th June 2009, 09:37
  4. tyres/tracking
    By happypostie in forum Detailing and Car Care Discussion
    Last Post: 5th June 2009, 21:12
  5. Tyres & Tracking.
    By CBR600FV in forum Handling & Braking
    Last Post: 12th November 2008, 21:11
