Thread: MPG Booster
    Regular Member MattW's Avatar
    Sheffield
    Default MPG Booster
    Autoexpress have done an article on the plug in tuning boxes
    http://www.autoexpress.co.uk/news/au..._boosters.html
    Kent
    The facts in the story are somehwat questionable. The mpg difference should not be checked via fuel comp as boxs often throw the figures out. I imagine the power gain was greater than suggested as the std car figure will be incorrect if they drove there with box on (always recommended so that the ecu learns) then took it off for the std run, as the prssure in the rail wouldnt have dropped off giving a unnatural power figure. On saying that I am getting 35% power and torque uplift over std and circa 10% better mpg with my box currently. (DTUK)
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It sounds like it simply modifies the rail pressure value, this mis-reporting then changes the high pressure pump operation.
    If the rail pressure is higher than reported, more fuel will be injected than the ECU calculates, and therefore the onboard fuel economy computer will be wrong. It only measures 'commanded fuelling rates' and not actual fuelling rates.
    Personally, I don't think they have 'proved' anything. A much longer use pattern would be needed to statistically prove a FE benefit.
    Plus you'd have to drive it for a couple of years to just break even. If you want more power, do a proper job and remap it. If you want better economy, change your driving style or your car for a more economical one...
    Full Member Big Sig's Avatar
    Yep as said, boxes through the computers way out. Only way to work that out is the old fashioned method over a decent milage for a good sample.
    Belfast
    Yet another quality AutoExpress article. Sarcasm mode off.
    DPT has also struck a deal with Titan Travel, a firm specialising in trips to sporting events such as the Le Mans 24 Hours. All 160 of its VW minibuses have been kitted out – and drivers have reported an eight per cent reduction in emissions.
    Oh really,, how did they do that then?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Reduction in personal emissions, like farts ? ? ? ?
    Oct 2006
    Waterloo, Liverpool
    8 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    " a ‘plug and play’ solution that doesn’t alter your car’s ECU or remap the engine."
    For only £350 .....you're having a laugh.
  1. Octane booster
    By gibbon7000 in forum Petrol Engine related
    Last Post: 2nd February 2011, 10:57
  2. Booster Seats
    By Damian in forum General Chat
    Last Post: 1st November 2007, 14:19
  3. Octane Booster???
    By mark1319 in forum Vectra C / Signum Car Chat
    Last Post: 18th August 2007, 09:02
  4. Octane Booster ??
    By Bainie in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2007, 21:25
  5. Antenna Booster
    By Damian in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2007, 21:46
