Thread: Can anyone help????PLEASE
    Regular Member jared.ryder's Avatar
    Jun 2007
    NORFOLK
    Default Can anyone help????PLEASE
    i have noticed that when i gently press the accelerater when stationary, on my 1.8 06plate veccy, the revs dont climb smoothly and im thinking it could be the reason for its erratic pulling away. does any1 have any ideas what could be causing it to do this.??? any commments appreciated.
    Regular Member s0501291's Avatar
    Warrington
    I would guess that it is the accelerator pedal potentiometer/sensor. Because these cars dont have a throttle cable, its electroniclly controlled. Somtimes the sensor which relays the positon of the pedle to the throttle can have a few dead spots hence the inconsistent revs. I would guess that this is the most likely fault. But could also be somthing as simple as a sticky throttle butterfly valve/mechanism as again it isnt a throttle cable, its an electic servo/motor which operates the throttle. Just a couple of ideas anyway, hope this helps
    Pete
    Jul 2006
    Mexico
    As above...I think the pedal "sensor" might be faulty or you can try a reset on the ECU´s that might help. Also a software update can help maybe.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    As it's still under warranty, why don't you take it to your friendly dealer and get them to have a look at it for free?
    Jun 2007
    NORFOLK
    Thanks for all replys, much help. cheers
    Regular Member jack's Avatar
    slaming doors since 1976
    good luck pal.
