Results 1 to 10 of 11
Thread: Vectra C Facelift Sidelight Fitting
    Regular Member MrLOL's Avatar
    Wakefield, West Yorks
    Default Vectra C Facelift Sidelight Fitting
    I've read the discussion in the How 2, theres one on there which mentions removing the bumper
    But in the how 2 discussion it was also discussed that its probably easier to remove the airbox
    But theres no how 2 for removing the airbox, and im very dubious about doing it with the VXRs airbox being so big.
    For VXR pics see here http://www.vectra-c.com/forum/showthread.php?t=15060
    but im very nervous about doing both. Trouble is ive got to now, as ive got a cool blue on the right sidelight, but a nasty yellow one on the left one. No backing out now ...
    it's dead easy.. just remove the intake trunking off the airbox, pop the lid off and remove the filter.... then pull the airbox up and out.. it's dead easy to get it out...
    or you could just use a crowbar....
    Feb 2006
    Guttedsville
    Mine were very easy to change......
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    think thats difficult....you wanna ask Plasma how he has to change his indicators bulbs lol...........i couldn,t believe it when he told me
    ok bearing in mind your talking to a novice here. What tools am i going to need to do the job.
    Screwdrier for the jubilee clip and some brute force ? because i panicked when i saw the CDTI airbox thread and torx screws being mentioned. Dont have one of them
    Regular Member Robbie69's Avatar
    As you've said, undo the jubilee clip and pull hard whilst wiggling it about. Think there are three rubber mounts, it's quite simple really (mines a 1.8 petrol).
    Jul 2006
    While you're in the engine bay, any chance of taking a picture for me?
    Apparently the VXR airbox has a hole about 5 or 6cm diameter underneath the filter to help with induction. I want to drill my own hole, but don't know yet exactly where to drill it...
    Would be appreciated
    will do mate. Im going to be tackling it at the weekend when i can get some proper daylight. I dont finish work till 5, so by the time i get home and am in a position to do it, the lights fading.
    well i did it
    easiest way to do it is to unscrew the 2 jubile clips for the airhose, leave the airbox in place and that gives you just enough room to get your hand in without scraping it.
    Parapaul, where exactly was i looking ? looked down the side of the airbox and theres no holes in it mate, this was above and below the join line in the middle. But as said, i didnt take the airbox apart, just remove the feed to it.
    Jul 2006
    I'm under the impression the extra hole is either in the floor of the airbox or low down on the front wall...
    Thanks for looking though
  1. Front fog fitting on facelift vectra
    By Ace1981 in forum Styling
    Last Post: 18th July 2012, 13:38
  2. Fitting foglights to facelift vectra life
    Last Post: 10th December 2010, 16:33
  3. Facelift O/S Sidelight
    By Exclusive BV in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2010, 21:13
  4. Facelift Sidelight Replacing
    By nickabbott2008 in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2009, 12:40
  5. Changing Sidelight Bulbs In Vec C Facelift
    By VSRI in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2009, 20:59
How to change sidelight on vectra c face lift
