Results 1 to 10 of 11
Thread: Brakes and MOT
    Regular Member hagga's Avatar
    kingswinford
    Default Brakes and MOT
    now i remember back in the day (maybe just me though) that ya used to get car mot'd and they'd say for example..'yeah..all good..but pads need changing soon etc'. I had MOT at VX last monday..passed no problem BUT!..had to have rear discs/pads replaced today as they were metal to metal..had heard slight scraping just before MOT but as was running in new front pads so thought nothing of it. Spoke to VX and they say they don't check pads etc..they just bung it on roller machine and if it stops ok then it passes brake test.. Is this right?..needed car today but it ended up in kwikfit( normally do them myself..but had come off night shift lol)
    all they can do is fail the car if the pads have dug up the discs by rubbing metal to metal contact, low pads are not a failure...if the car generates enough braking force on the rollers then it will pass, even if the pads only have 1mm of pad material left....
    If your wheels obscure the view of the calipers then they can only note that they could not view the state of the pads....
    kingswinford
    thats a bit poo lol..needed to go down kent today..ended up sitting at home twiddling thumbs
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    an mot tester cannot fail something that cannot be seen so unless there is some visble damage to the disc or they are making a loud noise as already mentioned the brakes will pass if up to the correct performance,same as rear wheel cylinders will pass even if they are leaking slightly,if the car has a service previously to the mot so long as the brakes are upto the correct performance they will pass
    Ashington, Northumberland
    Less than 1mm of pad material will result in a failure. ONLY if the tester can see the pads though. any brake fluid leaks will be a reason for rejection (if visible of course), if the wheel cylinders have got to the stage that the leakage is evident down the backplate and onto the wheel, you can almost guarantee that the shoes will be contaminated, giving a low or no braking effort result on that wheel anyway. If it was that bad, I wouldn't carry out the RBT in case I caused further damage.
    Regular Member Vectra-Dog's Avatar
    Birmingham
    Had my cavalier fail on rear pads before. They could only see them as i had open spoke alloys on it. I guess as said previously if they can't see them they can't fail it.
    At least you found out what the noise was.
    kingswinford
    Quote Originally Posted by Vectra-Dog View Post
    At least you foud out what the noise was.
    yeah..but after being on nights..'twas a trip to kwikfit..wern't in the mood to sort them myself lol
    Tyneside
    A good tester will have a thorough look at everything IMO, I would rather have a guy being anal about it than someone just flying it through and pass it.
    kingswinford
    Quote Originally Posted by mark1319 View Post
    A good tester will have a thorough look at everything IMO,.
    this was my point..a lot of independent garages have advised in the past...as for pads not being visable..have vx not heard of mirrors?..
    Regular Member VXR_DV's Avatar
    South Coast
    I got a bit wound up with the V*lkswagen garage locally. The wife's Golf had a full (inspection) service which included checking the brakes, with a view to passing an MOT in a couple of weeks time.
    Fair enough, it comes back with "rear pads/discs worn", which I had done, but it failed the MOT two weeks later on "Handbrake mechanism insecure".
    WTF? It had the service two weeks previously: I had assumed that they would check the brakes at the service to a standard that would pass an MOT, but it appears that it isn't the case
    dv.
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Brakes
    By Si-SRI in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2011, 10:21
  3. my brakes
    By bigron1988 in forum Handling & Braking
    Last Post: 27th November 2008, 08:03
  4. Big brakes on my GSI?
    Last Post: 7th May 2007, 21:07
