Thread: permanent live
    Full Member lizard's Avatar
    Oct 2006
    southampton
    11 Post(s)
    Default permanent live
    Speaking to someone else on here earlier and we both have roughly the same headunits and they only work with the ignition on. all steering wheel controls function but cant use the stereo with keys, is there a way round this or not... all help greatly recieved
    Regular Member MattW's Avatar
    Sheffield
    Quote Originally Posted by lizard
    Should that read "Can't use the stereo without keys"?
    I've got a Pioneer DEH7000UB and I can't use mine without the ignition being switched on either. I'd also like to know if there is a way around this.
    Regular Member Robward27's Avatar
    Witham
    Perminant live is taken from the ciggerete lighter see this post:-
    http://forum.vectra-c.com/showthread...perminant+live
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I have the same problem. Switch on & off is a function of the CanBus so the only alternative is to make both live connections permanent & switch the radio on & off via the radio itself. Someone may do a CanBus power adaptor but it's likely to be very expensive.
    Surrey
    Which is why people find a switched source.
    Sheffield
    Quote Originally Posted by steve1975l View Post
    Which switched source do people use then rather than taking a second permanent live from the cig lighter?
    Surrey
    Ciggy lighter is the easiest one.
  1. permanent 12v live
    By rockafella8587 in forum Electrical & ICE (including SatNav)
    Last Post: 28th December 2012, 17:53
  2. Wiring an amp, need an ignition live and permanent live in the boot
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 16:36
  3. Permanent Live in Boot?
    By bandrew in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2009, 15:03
  4. permanent live to cig lighters
    By signum stew in forum Electrical & ICE (including SatNav)
    Last Post: 8th July 2009, 22:50
  5. Permanent live issues
    By martinbruce in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2008, 13:29
vectra c permanent live
