Results 1 to 10 of 14
Thread: ESP and Traction control
    Regular Member SwavGav85's Avatar
    Inverness
    Default ESP and Traction control
    Can any one tell me how I would fine out if my car has ESP? I'm pretty sure it has traction control, as when I boot it, it lets me spin for a sec then kills the power , Tried getting a traction control button but it only lights up and does not switch the TC off!
    I'm driving a 55 Plate Vectra SRI 1.9 Cdti (150 facelift)
    Any advice would be good
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    when you turn your ignition on look on the dash (between the speedo & rev counter)there should be a car with wavy lines under it
    if you have traction control you will have ESP on the facelift
    click the link below
    Mileage : 000
    I am told that if you look on the side of the ABS module there is a paper label, in amongst the other information it will have ESP writen on it. Unless it can be fitted as an option on the 1.9 I don,t think you will have it on yours. It was fitted as standard on the V6,s. Though.
    Inverness
    Wow thanks for the quick reply! Will look on the ABS module, When i turn the ignition on that light does indeed come on, so i defiantly have TC, but ESP is only a possibility.
    In regards to the TC button is there any way i can get it to turn of the TC??
    if you have the button, you can just press it to turn it off...If you have no button, pop the blank out and see if the blue plug is there...if it is, and you chose to try and fit a switch you have a 50/50 chance of getting it to work...
    Inverness
    Yeah thats the problem, I bought the switch for retro fitment, I have the switch all it is willing to do is light up
    in that case it's a no-goer for switching it for you....... you will only be able to turn it off with TECH2
    Inverness
    I'm new to this, so this is where I'm going to show my ignorance! TECH2?
    Its the main dealers diagnostic and programming tool for the car...a snip at £4.5K....
    you can pay them £50 to turn it off.....
    Inverness
    Why would you want them to turn it off?
  1. my traction control how to
    By jpbroad1970 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2012, 20:01
  2. traction control
    By ggg1979 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2009, 18:07
  3. 2.0T Traction Control
    By kryton01 in forum Engine & Drivetrain
    Last Post: 20th October 2009, 17:18
  4. traction control
    By jsnlvxr in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 21:56
  5. traction control
    By jamesv6 in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2006, 00:13
