Results 1 to 10 of 11
Thread: SRi 150 Cambelt/Chain
    Wakefield
    Default SRi 150 Cambelt/Chain
    Hi all, have done a search, but confused...
    I have a 55 reg 150ps SRi cdti Vectra facelift, just gone 63K Miles on it, have heard it has a chain and doesn't need replacing?
    Does it have a chain or is it a belt that needs replacing, please enlighten me on this..
    (will be doing the "spring sleeve mod" and antiroll bar bushes as well this week.
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    belt as far as im aware
    only the 2.2 is chain
    but some in the know will be along to put me rite.
    Full Member Big Sig's Avatar
    150 is a belt but has 80k intervals. But would recommend changing it at 60k along with the tensioners and water pump
    Birmingham
    CDTI 120 and 150 is deffo a belt as I had to have one of the bleeders changed (unknown at the time of purchase that it was belt driven).
    Changing at 60k is good, better to be prudent although some Vx dealers actually told me that it 100k or 10 years but later changed.
    Get it done mate, no point risking it, especially if you plan on keeping the car.
    Tx.
    Bye bye Vec B
    - Hello Siggy!
    Regular Member Gripper's Avatar
    Middle Wallop Andover
    Am I right in assuming this is very expensive and a long job both to do yourself or for the dealer to carry out?
    Birmingham
    Expensive: yes, as is everything else with stealers.
    DIY: ???? Good question, I wouldnt like to try it.
    I had a few bits and pieces done at the same time, think it set me back about £350 - £400, or somewhere there abouts.
    Still worth it though as a replacement second hand engine is minimum £750, and thats if you can find one.
    HTH.
    Bye bye Vec B
    - Hello Siggy!
    Wakefield
    Thanks for letting me know, i thought they it had a chain, and wasn't going to chnage it..
    Anyway just ordered it from the local VX £111 for the full kit, not orderd the water pump, will check if needed. Also ordered the insulator sleeve for the spring knock/noise...
    Just need to find a good place to get it done now, can't afford the stealers prices...
    Things have changed a bit - the petrols are chain driven and the diesels belt, by and large...
    Birmingham
    Quote Originally Posted by Imi View Post
    Same as mate, I thought it were chain driven too until I read and advert for another car and rang Vx.
    Beats me why the newer engines have belts and the older ones chains, should be the other way round.
    Bye bye Vec B
    - Hello Siggy!
    May 2006
    scotland
    I would get a new water pump at same time. You may do the job and put the original pump back on only to find it leaks after it is up to operating temperature, in which case, you will be doing at least half the job again. I had this experience on an old cavalier years ago.
  1. Cambelt/chain?
    By kev bux in forum Engine & Drivetrain
    Last Post: 13th March 2012, 22:31
  2. Cambelt or Chain
    By panos9 in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2011, 16:39
  3. Cambelt or chain
    By planetgarb in forum Engine & Drivetrain
    Last Post: 2nd August 2010, 13:08
  4. cambelt or chain????
    By gibbon7000 in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2009, 20:27
  5. Advice on cambelt or chain
    By Perry in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2007, 17:42
