Thread: electrical problem
    cumbernauld scotland
    Default electrical problem
    hi i have a vectra 53 plate 2.2 dti with 150,000 miles i am currently having problems with the abs and anti skid light coming on also the speedo is not giving the proper reading it goes up and down while driving also the seat blt warning busser is going on as soon as the car is started .
    can nyone suggest what this could be
    thanks gary
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The speedo, ABS and TC sound like a wheel speed sensor is not operating correctly. Either the sensor, wiring harness, or the speed ring itself need checking for damage, dirt ! or insecurity.
    Selt belt warning buzzer sounds like the switch in the belt clip recepticle is not operating. Either fix the switch or cut the wires that go into the drivers anchorage and join together if necessary (can't remember if they are join or break to silence)
    Default electric fault
    the wheel bearing was replaced last week and before it was the abs and tc light was on but when fixed it went out
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    So the light was on before the bearing was replaced and when the bearing was repaired the light went out? So your 'current problems' are not there now?
    yeah the abs light wason before the wheel bearing was changed but now the speedo is faulty
    speedo readings are picked up from the ABS sensor...
    Have you had the car on a diagnostic machine??...it could be anything from another dodgy wheel sensor, to a dodgy panel or CIM fault...
    well i fitted a new wheel bearing last week and all was fine then last night the speedo went funny and abs and t/c light came on i was wondering if i took conection to abs sensor off and cleaned if that may help
    the sensor is part of the internals of the wheel bearing, so it's not really serviceable....but you could check the connectors.....
    if not, it's a really good session on the diagnostic machine..
  1. Wiper Electrical Problem? (Not sticking or cold weather problem)
  2. electrical problem?
    By tjr2011 in forum Bodywork & Interior
    Last Post: 31st March 2012, 16:42
  3. Electrical problem, please help!!!!!
    By alancollier in forum Electrical & ICE (including SatNav)
    Last Post: 5th July 2010, 18:44
  4. Electrical Problem??
    By pilsbury in forum Engine & Drivetrain
    Last Post: 12th May 2009, 01:57
  5. Electrical problem please help
    By alshel in forum Electrical & ICE (including SatNav)
    Last Post: 17th September 2008, 22:54
