Thread: Injectors not turning on
    lincoln
    Default Injectors not turning on
    hi my cdti wont start due to injectors not turning on no fault code present any ideas thanks
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    How do you know injectors aren't working if no codes?
    lincoln
    put a light tester in injector plug socket to check for power it never lit up so no power reaching injectors but strange thers no fault code or spanner light
    LONDON
    i have the same problem, i have been advised one of the injectors needs replacing, i have a 1.90 cdti engine code Z19 DTH model, its 2005 year diesal vectra, does any one know if these injectors can be changed by a layman and if any special tools are required or is this a job for a specialist if so any recomendations in the south east london area. Finally what make and model the injectors are on this vectra? thank you
    Oct 2007
    estonia
    the new injector code (on top of the injector) has to programmed to ecu with tech2. so you can not performe the job 100% by yourself. unless you own a tech2
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    if you buy it and fit it, depending on how local you are in London i could program it in for you. where abouts in London u located?
    LONDON
    Plasma, got the situation resolved turns out it was not the injectors but the connection to the injectors, i am in south east London, catford, where are you, as i may need to replace the injectors any way, and or the wiring loom around the injectors as the car does not have the zing that it had when i first got the car?
  1. Turning an SRi into a VXR request
    By L11Marc in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2010, 07:08
  2. Turning Over
    By Diet1985 in forum Engine & Drivetrain
    Last Post: 21st August 2009, 22:49
  3. Looks like i'm turning.
    By shan in forum The 'Off Topic' room
    Last Post: 3rd February 2009, 13:55
  4. Turning your Wii 3d
    By rosssri in forum Games Room
    Last Post: 12th January 2009, 18:41
  5. Vectra not turning over?!!?!?!
    By djbasics123 in forum Vectra C / Signum Troubleshooting
    Last Post: 13th October 2007, 14:23
