Thread: Grill Deflector
    Regular Member chrishornby's Avatar
    cheshire
    Default Grill Deflector
    Is it worth removing the Plastic Deflector behind the grill, in front of the air intake, it looks like it restricts the air flow ?
    Forgot to say , on a pre-facelift
    lincoln
    no i would'nt as it stops water going into intake pipe
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    As nico said, its only fitted on the Diesel, from a consensus of opinion its there to stop hydraulic lock as they run a higher compression than petrol.
    EVERYWHERE
    Not worth doing.The flow meter is the most restrictive part of the induction system (around 60-70% of total restriction),and it's postioned after the air filter and is not to be messed with.So anything before that is not going to make a great deal of difference.Even if you completely remove the air filter chances are it won't make a lot of difference,and so removing the little bit of plastic in front of the intake is pretty much useless.
    cheshire
    I will leave it alone then.
  1. Wind Deflector how 2 please
    By philgst in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2011, 18:44
  2. Wind deflector
    By mickeystitch in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2011, 08:31
  3. anybody got spare deflector clips
    By vectra2.2sri in forum Vectra C / Signum Car Chat
    Last Post: 27th December 2010, 20:55
  4. 4 piece wing deflector
    By pinoy in forum Parts for sale
    Last Post: 25th May 2009, 21:12
