Page 1 of 6 123 ... LastLast
Results 1 to 10 of 57
Thread: Starting problems WITH A DIFFERENCE...HELP!!
    Birmingham
    Default Starting problems WITH A DIFFERENCE...HELP!!
    So i am very familiar with the notorious starting problem with 2.0dti etc where cars left for a few hours insist on not starting...most likely due to old leak off pipes or worn injector seals...allowing air into the system and causing fuel to drain out of engine back to tank.
    Well...my car problems are different...not related to hot or cold starts or for that matter i cant see its related to anything. On occasions, it starts 1st time on my drive, i drive a couple of miles, park up for 10 mins, and when attempting to start the car again..its takes cranking of upto 10-15mins (in 8 second bursts) to get it going...and sometimes it doesnt even wish to start..at which point i hope the bus doesnt take forever to come!!!On some occassions, it doesnt start at all on my drive one day...then the next morning it fires up 1st go!..ITS SO RANDOM!!
    Not sure if it helps but i have been parking on a hill facing down the hill and it has possibly helped but im not positive..though that doesnt help once i have parked up in the local supermarket!!
    Any suggestions would be much appreciated as this needs to be sorted...i dont enjoy paying the bus driver £3.00 for my bus journey home!!!
    Regular Member Darryl2.2DTI's Avatar
    Oct 2007
    Kilmarnock, Ayrshire
    Vehicle : Vauxhall Vectra C
    Trim : LS
    Engine : 2.2 DTI
    Mileage : 106000
    kinda stabbing in the dark but are the glowplugs getting enough power to them.
    mabey even a fueling issue. im sure there will be good advice given on here. always is. hope u get it sorted soon.
    Birmingham
    Quote Originally Posted by Darryl2.2DTI View Post
    thanks for replying as any advice is good..i really need this sorted without pumping cash on random things!
    The glow plugs will be fine as sometimes it starts up nice and quick in the cold..and plus once the engine is warmed up for about 10 mins...even crappy glow plugs shouldnt stop the car from starting.
    As for fuel issue...possible but why does it fail to start after warmed up and driving...but then might start first time the next morning? STRANGE
    Look forward to lots of help
    Oct 2007
    Trim : LS
    Engine : 2.2 DTI
    Mileage : 106000
    it is certainly a strange one. supose a can of petrol and a match would get it to fire up.
    sorry that was bad but u might feel better watching it burn.
    Birmingham
    come on guys....someone should be able to help...im having to use my cousin as the RAC recently as not having much luck with the car and he's always having to bail me out...someone must have some (good...not like burning the car!!) advice?????
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    My old B had the 2.0 DTI and I had very, very similar starting problems and that was the leak off pipes (even if I'd stopped to fill up, sometimes when I got back in the car it turn over but start etc, completely random as you say)
    I replaced them and I never had the problem again.
    Have you actually looked at/replaced yours?
    Birmingham
    Juzzy D...thanks for your reply. I wasnt whether to change the leak offs as the starting poroblem seemed so random....but from what you told me about yours...i might just do that this weekend. I have some pics on this post (link below) of my actual engine....it looks kind of grimey around the pipes so could be leaking.
    http://www.vectra-c.com/forum/showthread.php?t=59573
    is it just a matter of pulling them off with brute force and replacing...do the new one need some sort of glue to stick them to the injectors?
    thanks mate
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    how many miles does your car have mate?
    could it be that the throttle body and breather pipes are clogged.
    does the dti have butterfly in the throttle body? if so see if its clogged up with cr@p
    Birmingham
    Hey mate, dont know if this could be related, but my mate used to have a 1.7 TD Astra (yes the older ones), and when it got to the winter months (late October onwards) his car used to do exactly what you are saying: "it takes cranking of upto 10-15mins (in 8 second bursts) to get it going".
    In the end, he had a new battery on it, new starter motor, new injectors, new glow plugs and in the end it turned out to be the fact that his engine was losing compression (whatever this means).
    Unfortunately for him it meant a new engine.
    Once again though, I dont know if the this problem is the same as its 2 completely different engines, but certainly worth exploring if this is the same scenario (winter time, etc).
    HTH.
    Bye bye Vec B
    - Hello Siggy!
    Birmingham
    Quote Originally Posted by Sean-2.2Direct View Post
    Hi, engine has about 115000 miles on it..is a 52 plate. Im not toooo clued up on tech talk (although i know more then the basics)...but not sure what you mean by butterfly in the throttle body. Nevertheless...i no a mechanic but as he doesnt specialise with vauxhalls....at least i can tell him to look into the possibility of a clogged up throttle body. cheers
  1. 2.0 DTi - Starting problems.
    By Whosane in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2013, 01:22
  2. 2.0 DTI Starting problems
    By vx sri in forum Electrical & ICE (including SatNav)
    Last Post: 26th March 2012, 22:36
  3. car starting problems please help!!!!!!!
    By Big Red in forum Engine & Drivetrain
    Last Post: 5th March 2012, 11:29
  4. problems starting
    By jasoncow in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2011, 23:24
  5. Starting problems WITH A DIFFERENCE...HELP!!
    By shatz in forum Engine & Drivetrain
    Last Post: 12th October 2008, 18:39
